Old March 15, 2010, 06:04 AM
Default The order of the chilling
Such order of the chilling right?
res-----pump----2x5870----XSPC RX120----cpu block----XSPC RX360----res
Old March 15, 2010, 06:12 AM
gingerbee's Avatar
does not make a big difference what matters is your ambient with water. i prefer to run it res-rad-block but that's just me
Old March 15, 2010, 06:22 AM
MarkOne's Avatar
where is the chilling part ?
Old March 15, 2010, 06:42 AM
I cooled cpu i7 920 and Sapphire 5870CF. I wonder if the water is good and red if it is good that this is the first GPU and then the cpu
Old March 15, 2010, 07:19 AM
gingerbee's Avatar
I think you'll be fine. not really sure what you mean but if your wondering if those rads can handle the heat load off of those parts i think your ok.
Old March 15, 2010, 07:22 AM
chrisk's Avatar
Folding Captain
You are OK as long as the res is higher than the pump, and comes just before it.
Fold for team #54196
Old March 15, 2010, 10:08 AM
Here you attach an image should now look how my water cooling. I have the EK Bay spin reservoar. Now I wonder if such layout okay if you do not can you recommend how would you put water cooling in my case. Please if you could send a picture painted with water-cooled
Old March 15, 2010, 10:15 AM
Dazmode's Avatar
You are fine. Order make almost no difference, especially with strong pump.
Orange Build: Final Video
HTPC Build: Final Video
Old March 15, 2010, 10:48 AM
gingerbee's Avatar
yup and yup
Old March 15, 2010, 10:57 AM
I have a Laing D5 + EK TOP
should i order this for my new rig? SanjoTHEBanjo New Builds 4 March 9, 2009 11:22 AM
Anyone order from newegg.ca? E86 New Builds 24 December 24, 2008 02:58 PM
Petra's Order miggs78 Water Cooling 4 August 6, 2008 08:07 PM
Pick Up my order? Epsillon Off Topic 1 December 29, 2007 02:32 PM
DC order cancellations. Rinnerz Off Topic 4 December 8, 2007 01:13 PM
