Old March 15, 2010, 12:53 PM
Now I wonder if something reflected temeperaturah if the processor before another 1x120mm radiator?
Old March 16, 2010, 11:16 AM
Liu Kang's Avatar
Agreed. Res before pump is all that really matters, but most will go pump to rad to disipate the heat dump from the pump...
Personally, I would want more rad space... you are looking at 120x4 to cool 3 processing units, it's just not enough.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old March 16, 2010, 12:36 PM
It's plenty...
Old March 16, 2010, 05:47 PM
Liu Kang's Avatar
We shouldn't make blanket statements without more detail on the OP's setup. Regardless, to say that it's "plenty" is misleading IMO. The 5870s are notoriously hot, and any reasonable OC on that i7 will create a lot of heat as well...
LK
Old March 16, 2010, 06:12 PM
The OP specifically listed the parts that he'll be cooling, which is sufficient information.
5870s are not hot. They have quite low power requirements, and heat output is determined by power consumption. And yes, overclocking the i7 will create a lot of heat, but nothing that a 120mm and a 360mm rad can't handle with ease.
Old March 16, 2010, 07:29 PM
Liu Kang's Avatar
No OC info, no specifications on case setup, nothing regarding push/pull config or shrouds... all factors that can create/dissipate a substantial amount of heat.
Look man, I'm not going to go back and forth on this, it's kind of pointless... run the numbers through Skinnee's lab or look through bigger WC oriented sites, you'll be hard pressed to find avid WCers that will agree.
G'luck, M_T_M.
LK
Old March 17, 2010, 12:46 AM
So you recommend 1x120mm refrigerator before cpu?
Old March 17, 2010, 05:11 AM
gingerbee's Avatar
G'luck, M_T_M.
I think you need to spend more time water cooling the rads he's got if they don't do it all then you need to turn down the heat in your house a lot ( like down from 40c haha). i ran a 4850 a 4870 and an oc 920 all on a mcr 320 with 800rpm's yate loon's and had no problem at all in a house where the ambients temps reach almost 30 c which sucks yes but no problems with heat under full load.
edit: I have been water cooling pc for almost 5 years straight now. some many water cooled builds i lost count. luck is not need just take your time and set it up. logic
edit 2. this guys using an 1 320 adn his temps are fine. YouTube - Fully Watercooled, crossfire 5850, core i7 gaming pc - build video (HD)
  #19 (permalink)
Old March 17, 2010, 09:55 AM
Liu Kang's Avatar
I never said it wouldn't work... what one person consitutes as "fine" for temps, isn't what someone else might want to achieve either. Then again, I have 4 120.3s sitting on my desk, AMBIENT OR BUST!
LK
  #20 (permalink)
Old March 17, 2010, 10:18 AM
gingerbee's Avatar
oh ok i see what your say. good luck on that wow not just buy a big car rad or something then. kinda like squeetard
should i order this for my new rig? SanjoTHEBanjo New Builds 4 March 9, 2009 11:22 AM
Anyone order from newegg.ca? E86 New Builds 24 December 24, 2008 03:58 PM
Petra's Order miggs78 Water Cooling 4 August 6, 2008 08:07 PM
Pick Up my order? Epsillon Off Topic 1 December 29, 2007 03:32 PM
DC order cancellations. Rinnerz Off Topic 4 December 8, 2007 02:13 PM
