Old March 17, 2010, 10:36 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Ive done it 1000 times lol. I dont use a case for exactly that reason
Old March 17, 2010, 10:39 AM
MarkOne's Avatar
Originally Posted by lowfat View Post
It depends on the tubing you use as well. The way primoflex bites on to fittings there is no way i would try it. In my case i would loosing the fittings without a doubt causing a leak.
is it only me but the fezer are exactly the same hose.. of course fezer and primo do not manufacture them , they buy it some place.
Old March 17, 2010, 10:45 AM
Dazmode's Avatar
I know that Feser tube is made in Germany, not too far from them ... No idea about Primo source of tube.
Orange Build: Final Video
HTPC Build: Final Video
Old March 17, 2010, 11:04 AM
MarkOne's Avatar
Daz do you have a primo tube, I can send you one sample to see ...can be wrong but for me it's the same , and it will make sense too.
Old March 17, 2010, 11:10 AM
lowfat's Avatar
Definitely not the same tubing. Primoflex is silicon tubing. Feser is PVC.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 17, 2010, 11:12 AM
MarkOne's Avatar
may be they make 2 kid of primo flex, mine don't look silicone, they are 1/2" by the way .
Old March 17, 2010, 11:33 AM
lowfat's Avatar
I am pretty sure all Primoflex is silicon. Try squeezing the Primoflex tubing and notice how soft it is. PVC tubing (like TFC) is really card compared to it.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 17, 2010, 01:14 PM
you must not have kids!!!! :)
thanks for the help guys, I appreciate it. heres a quick photo of the PC, and from the looks of it, i should have some slack.
Have you ever had the back plate move on you or is it pressed to the back of the computer case nice and tight. I was thinking about that, about having all the screws undone and then the back plate moves...
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
  #19 (permalink)
Old March 19, 2010, 04:08 AM
sswilson's Avatar
If it's the original Swiftech backplate you shouldn't have any problems with it moving. The glue they used on the adhesive pad will survive armageddon and still not come off..... ;)
edit: BTW.... I'm guessing that the res is normally on the inside of the 5 1/4 bays? I can't imagine it would fit that way with the cover on....... (I could be wrong though).
  #20 (permalink)
Old March 20, 2010, 03:51 PM
thanks guys... all went well, and I'd have to say it took longer disconnecting the computer and carrying it to the table than it did changing CPUs....
worked out great!!!
cheers
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
So easy a monkey can do it Dr_BenD_over Off Topic 5 January 15, 2010 12:50 PM
CPU voltage not changing OTZ Troubleshooting 1 September 25, 2009 06:40 AM
[WTB] Looking for DVD player PSU (500watt)hard drive/s AMD cpu cooler Shadowmeph Buy/Sell & Trade 3 July 31, 2009 10:45 PM
watercooled cpu temps on non OC system Shadowmeph Troubleshooting 13 July 16, 2009 12:08 PM
[WTB] watercooled ati videocards. or 1 watercooled nvidia card kyle_L Buy/Sell & Trade 4 February 26, 2009 01:53 PM
