  #41 (permalink)
Old December 9, 2007, 07:19 PM
JD JD is offline
You're good to go! As for your questions:
zipties (also called tye-wraps) work just fine.
the Swiftech 3/8" clamps do not work on the 5/8" OD tubing. It has to be the Swiftech tubing.
metal clamps are called worm gear clamps.
distilled water is all you need. just add the water additive with the correct ratio.
One comment regarding the metal barbs: do not overtorque them, since the threads on the Apogee are plastic. You don't want to strip them.
John
Alright. So just screw the barbs in until they are just beyond snug? Basically hand-tight?
Once I get it all, can I leak test with it all installed but none of my hardware turned on?
Maybe with some paper towels or something covering things up. I really don't want to mount it all, then unmount it all, then mount it all. I guess it should be run overnight, even though I'll be so anxious to just get it all up and running...
  #42 (permalink)
Old December 9, 2007, 07:28 PM
3.0charlie's Avatar
Barbs are torqued Hand-tight + 1/2 turn. The trick is to compress the o-ring just enough.
You have to leak test overnight. Connect the pump to a molex connector and jump the main PSU harness (pins 4 and 6, green and black wires) to start the pump. You may need to add a few fans to the other molex connectors, to add some load to the PSU (some don't start with barely any load).
Assemble your loop in your case, with no components installed. This will bleed the system too of any air bubbles.
Hydro-Quebec is salivating...
  #43 (permalink)
Old December 9, 2007, 08:31 PM
JD JD is offline
So, mock mount it all up, take out the motherboard, let it run overnight. Then maneuver the motherboard back in, mount the block and power it up. Sounds tricky...
Better safe than sorry I guess though.
  #44 (permalink)
Old December 9, 2007, 08:36 PM
3.0charlie's Avatar
Yup, that's about it. And yes, better be safe than leaky. I know, it happened on my second wc built... since the first one went so well, I thought "no need to leak check"... yeah right. Cost me a 680i. You learn by your mistakes, or from others.
Learn from others, it's cheaper.
And take your time.
John
  #45 (permalink)
Old December 10, 2007, 09:13 AM
JD JD is offline
Ouch that sucks. Well I'll play it safe then. Won't be able to afford anything after this, and I've already gone through one motherboard
Watercooling in the Antec 900 - few questions James_8970 Water Cooling 32 January 6, 2008 01:48 AM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
EVGA GTX/Watercooling frosty Video Cards 0 October 1, 2007 03:32 PM
questions regarding watercooling elninio Water Cooling 18 July 29, 2007 09:36 AM
Watercooling an antec 900 moditir Water Cooling 11 July 15, 2007 08:02 AM
