Old March 11, 2010, 07:01 PM
MarkOne's Avatar
Default rotary barbs
hi, I use for the first time rotary 90' barb on my WC, and I don't feel secure, enough to want to remove them, I see a potentiel risk of leak there.. I'm too much worry about it.
Old March 11, 2010, 07:59 PM
Dazmode's Avatar
The only risk of leaking for rotaries is when you pull them hard sideways. Then they may leak... Other then that I have yet to see any problems with rotaries in any of my builds. I'd say : relax.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old March 11, 2010, 08:25 PM
SugarJ's Avatar
While I normally agree with Daz, I've had issues with some BP rotaries. They had a few bad batches. But if they don't leak right away, they are good.
Old March 11, 2010, 08:35 PM
Jackquelegs's Avatar
I've had one leaky rotary because of the Oring in the rotary part was somehow sliced open
Iapetos
Zephyranthes
Old March 11, 2010, 09:36 PM
ottoyu34's Avatar
I have used 4 of those so far. 100% leak proof
ATCS 840| Core i7 920 - 4.2Ghz - H20| Corsair Dominator GT 1600Mhz 6GB| EVGA X58 Classified| GTX480 2-Way SLI| WD 640GB X2 (Raid 0)| Corsair HX1000W
Old March 11, 2010, 10:09 PM
When I had a loop I had many, no issues. The only thing to ever leak that was rotary was a male-male fitting and it was a slow leak. The O-ring in it was messed up, but generally if it comes in a working condition, it won't have any issues.
Old March 12, 2010, 06:34 AM
MarkOne's Avatar
this is the one I worry about, it's only 2 " long and no chance of side movement, and with the shim I install betwen the barb and the block , they are perfectly align , changing it with 2 strait barb will means a uggly short loop, hard to not bent too, but still I see a potential of problem here.
Old March 12, 2010, 09:53 AM
SugarJ's Avatar
With no chance of side movement, you won't have an issue. Like I said before, if the rotaries leak, they do it immediately, and it will show up during your leak testing.
Old March 15, 2010, 02:07 PM
MarkOne's Avatar
Originally Posted by Chere View Post
Wow cool.
it's cold too .................
Rotary phase cooler by ruffus Eldonko Water Cooling 34 May 28, 2010 09:25 AM
75% off 300pc rotary tool accessory kit! mo' power Computer & Electronics Hot Deals 13 November 13, 2009 10:31 AM
[WTB] 3/8 Barbs. rai_polo Buy/Sell & Trade 0 October 28, 2009 08:29 AM
[WTB] Bitspower 45 Deg Rotary Fittings SugarJ Buy/Sell & Trade 1 August 3, 2009 09:52 AM
placement of barbs flybye Water Cooling 2 February 13, 2008 02:53 PM
