  #31 (permalink)
Old March 11, 2010, 07:22 PM
Dazmode's Avatar
I might be mistaken, but I was under impression SR1 is same thickness as MCR, while GTX is double thinkess of MCR. By bad then...
Orange Build: Final Video
HTPC Build: Final Video
  #32 (permalink)
You have to balance parts so one part won't damage other parts performance
Damage occurs when you have aluminum with copper in the same loop.Other wise i don't think you can damage a part. One more think : A lot of people forget about price-performance ratio.
www.miculhomereno.com
  #33 (permalink)
Old March 11, 2010, 07:24 PM
AmuseMe's Avatar
Its all good Daz, was just stating my opinion/ knowladge. Oh, also the SR1 is HWLabs flagship radiator right now - they claim it "Yields up to 30% more heat exchange capacity than the Black IceŽ GTX".
DEAD CA$H
  #34 (permalink)
Old March 11, 2010, 07:27 PM
Dazmode's Avatar
Need to catch up on my reading!
  #35 (permalink)
Old March 11, 2010, 08:00 PM
MarkOne's Avatar
can someone can catch up,, it`s 28 years I'm reading
  #36 (permalink)
Old March 12, 2010, 08:08 AM
BigDogg's Avatar
Originally Posted by AmuseMe View Post
Every rad is a little bit different. Most of which, that I have known about are quite the pain. If you go through with cleaning them, and get G3/8 adapters or barbs, than you wont be disapointed.
Personally, they just don't seem worth all the hastle to me - thats all.
Ok,
I wanted to report back about this rad. I was scared last night so I spend most of my evening shaking the crap out of my radiator. I first flushed it with straight boiled distilled water which came out perfectly clear. On the advice on some forum posting flushed the rad 3x with a 30% Isoproply alcohol and 70% boiling distilled water mixture came out a little cloudy the first time but clear the next few times. I then flushed it about 4 more times with boiling distilled water and there was no white flux anywhere. Unless I am doing something wrong the rad seemed to come very clean. I know Thermochill is under new management so maybe they have improved their quality control? This rad was straight from Thermochill as it was a new shipment to Direct Canada.
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
New to water cooling SquattingDawg Water Cooling 30 July 12, 2009 03:40 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
