  #41 (permalink)
Old March 23, 2010, 03:34 PM
JD JD is offline
I couldn't care less about Furmark temps. They simply aren't realistic and just put unnecessary stress on the card IMO.
  #42 (permalink)
Old March 23, 2010, 03:52 PM
AmuseMe's Avatar
(+1) No doubt. I find it pointless to do someting like that, but at the same time, it really shows how good your cooling set-up is.
  #43 (permalink)
Old March 23, 2010, 06:41 PM
JD JD is offline
Well I'm not here to set any records
I just like my PC to be quiet, which it is, and it runs cooler than stock. No doubt my temps would be worse than most seeing as I only have 1450RPM Gentle Typhoons on my radiator...
  #44 (permalink)
Old March 24, 2010, 04:48 AM
Levesque's Avatar
I was not asking for ''records''. LOL! You were talking about your temps, but gaming is not really pushing your card and waterblock. If you really want to see what your cooling system can do, and to see if you did install your block properly, then Furmark is a good indication of how your system would react to extreme conditions, and evaluate your block seating. That's all.
Since you were not sure of how to install the EK block properly, my suggestion to use Furmark, instead of gaming, was to help you really test your installation. Nothing else. :)
Here's mine btw, since I never take pictures, I took one this morning. I'm really not a good photograph. 5970 + 5870, EK blocks. :) Still alot of wire management to do, and lol! unwrapping the top, but I'm almost there! I'm too busy gaming!
3 triple rads, 2 loops, in a Mountain Mods Extended Ascension. For now I call it the ''Borg Cube''. :) Even the 5970 look ''small'' in there!
  #45 (permalink)
Old March 24, 2010, 09:07 AM
JD JD is offline
Well the way I see it, if I can run all my games fine at low temperatures, then it's mounted fine and working properly. We all have our own ways of testing things, that is my way.
Reference cooling had my poor GPU running at like 100C after some SupCom 2
And nice setup you got going there.
  #46 (permalink)
Old March 24, 2010, 10:02 AM
Levesque's Avatar
Like I always say: I don't ''play'' benchmark. :) But to me, Furmark is useful to see if everything is set-up properly, particularly to double-check the VRMs temps.
Reference cooling for the 5970 is really poor, and LOUD!
The goal of my watercooling set-up was silence. And it works. It's almost ''fanless''. My fans all run at 600-700 rpm or under... whisper quiet. The 2 cards, 5870 + 5970, with stock coolers, were crazy loud, like a jet engine!
  #47 (permalink)
Old March 25, 2010, 02:37 AM
nasrott's Avatar
Just got a new 5870 card on the weekend what do ya recommend guys? Running 3/4" primochill tubing. Consider something that Daz has in stock. Have a swiftech full cover block and also a mcw60 from the kit mentioned in the sig. Am after a new block for vid. Is is possible to use what blocks I have now, noticed a ram sink that takes the mcw60 on pts, has anyone tried this?
Waterblock for HD5870? Z Overlord Water Cooling 15 October 11, 2009 09:26 PM
[WTB] WTB: Fullcover 4890 waterblock Chilly Buy/Sell & Trade 10 September 8, 2009 03:38 PM
[FS] FEELER 8800gtx with fullcover waterblock RONEDOGG Buy/Sell & Trade 9 August 28, 2009 11:37 AM
[WTB] 4890 fullcover block n-sanity Buy/Sell & Trade 0 August 5, 2009 08:05 PM
[FS] HIS4870 with Fullcover//Watercooling Parts phil3_66666 Buy/Sell & Trade 69 May 11, 2009 03:10 PM
