Old October 17, 2007, 12:17 PM
chibi_man's Avatar
Originally Posted by Misoprostol View Post
3/8" tubing will not yield even a 1C increase in CPU temperatures. It's definitely not enough to call it a difference imo. You will not notice 1/2" vs. 3/8" in every day usage, and you probably don't have the tools to notice it through benchmarking.
I agree with that... you would need to do a bunch of test with different systems in order to make a good conclusion. I just stick to the text book on this one.
_____________________________________
If you can't beat it...
Old October 17, 2007, 01:06 PM
MpG's Avatar
MpG MpG is offline
As I understand it, the G1/4 fitting sizes used in most current WC stuff have an external thread diameter of 1/2", which effectively makes it impossible for the inside diameter to match up to 1/2" tubing. That was the reasoning behind Thermochill using the "Who the stocks this" G3/8 thread for their rads.
Old October 17, 2007, 01:26 PM
Misoprostol
Guest
Posts: n/a
http://www.ncix.com/products/index.p...re=Thermochill
Old October 17, 2007, 04:39 PM
MpG's Avatar
MpG MpG is offline
Yeah, I've got 'em now. Ordered a half a dozen back when the PA120.2 was a sponsored deal, they finally came in a week ago. They were out of stock for the longest time, tho.
Old October 17, 2007, 05:04 PM
Supergrover's Avatar
LOL Yeah you wernt the only one waiting on them
R.I.P.
