Old March 1, 2010, 09:07 AM
Varroa's Avatar
Default Swiftech Apogee drive died on me!!!
Wow, on Saturday my computer started to randomly "die" on me. It would just shut off (power off) with no warnings or nothing. After some simple diagnostics in the bios I was able to determine that my CPU was overheating. I opened my case and touched the Apogee drive only to discover there was no vibrations coming out of it. It was also making a slow clicking sound. So, I brought my rig into my workshop and proceeded to figure out how to remove the Apogee drive from my system which has two loops and a communal res. I tilted my system to try and drain the CPU loop into the common res when I noticed water dripping onto my video card!
I dismantled my entire system and it looks like my Apogee drive not only died but also started to leak. I ordered an OCZ Ven 2 in the meantime and I am going to re-assemble my second loop only (video card and NB) and run the CPU on air for the time being. I was never too happy with the apogee drive for cooling (it managed to only cool as well as air anyways) so I won't be going back to water on my CPU for a while I think.
GAMER: Win7 Pro x64, Q9550 @ 3.6Ghz (Coolit ECO A.L.C.), Asus P5Q Pro Turbo, XFX 6950 2GB (EK FC watercooled), Gskill 4x2GB DDRII 1066, OCZ Vertex + 120GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX620W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, ATI 3450 512mb passive, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old March 1, 2010, 09:50 AM
Water systems are perfectly fine.
Unfortunately you went a route that most people don't recommend and it burned you.
Old March 1, 2010, 10:02 AM
gingerbee's Avatar
ya an apogee is not a good judge for what water cooling can do. my water cooling right now has only one crappie fan on it. on a triple rad ( i am to lazy to change it yet ) and in the same room is my venomous and my water cooling is always 5c to 10c lower just because it's water.
Old March 1, 2010, 10:20 AM
AmuseMe's Avatar
The only thing an Apogee Drive is good for is to take it apart, mod it (to a Laind DDC 3.2) and use it as a pump only You'll want a "real" waterblock if you want better than 'air' cooling. :)
Old March 1, 2010, 01:39 PM
KaptCrunch's Avatar
yip thats the best route to go an get ddc top and curent waterblock that fits where old unit didn't like a i7 Water block
OP thats if....... pump still works after leak damaged
Old March 1, 2010, 05:14 PM
Varroa's Avatar
No idea if the pump still works. It was just ticking and not moving when I check last. I have a different pump I could use as well but I am just going to stick with air on my CPU until my next CPU upgrade. Thanks everybody.
Old March 1, 2010, 06:52 PM
lowfat's Avatar
Pump still under warranty?
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old March 2, 2010, 11:17 AM
Varroa's Avatar
Probably not, I think the pump is around 2 years old.
Swiftech Releases New Waterblock Apogee XT MpG Press Releases & Tech News 12 October 12, 2009 09:19 PM
[WTB] swiftech apogee drive or similar Cowboy Buy/Sell & Trade 6 September 26, 2009 09:41 AM
Swiftech Apogee GTZ in stock at NCIX! Cptn Vortex Water Cooling 1 August 20, 2008 03:31 PM
Swiftech Apogee GT question Vinnie Water Cooling 8 February 23, 2008 03:43 PM
Swiftech APOGEE Drive JD Water Cooling 14 August 16, 2007 11:35 PM
