Old October 16, 2007, 06:00 PM
Default Where the water go...
I installed a water cooling 3 months ago. I can see that I gona have to fill it a little bit. I don't see any leakage. Is someone knows where the water go
Thank you
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old October 16, 2007, 06:03 PM
water + heat = evaporation
Old October 16, 2007, 06:53 PM
Wankerfx's Avatar
Do you have an opening somewhere in your loop, like a reservoir? If you do, then you have evaporation going on. It's normal, so don't be alarmed.
[ER]
Old October 16, 2007, 07:20 PM
MpG's Avatar
MpG MpG is offline
Another possibility is that you have a micro-leak somewhere in your system - one which is so small (and slow) that the coolant actually evaporates as fast as it leaks.
Old October 22, 2007, 05:47 PM
Tubing is ever so slightly porous. Water permeates through, and that's where the water goes.
Old October 22, 2007, 05:56 PM
Misoprostol
Guest
Posts: n/a
Yugen's response is bang-on.
If you use Swiftech's norprene tubing, you can avoid this, but other than that, you're stuck with it.
Old October 22, 2007, 06:16 PM
Apollo4g's Avatar
Also take into the factor when you first filled your loop there was most probably small bubbles stuck everywhere in your loop. Places like the radiator, waterblocks, etc.
As time goes by these bubbles aggravated and are set into the flow of the liquid.
It then ends up in your reservoir/t-line decreasing the level of fluid in your reservoir to compensate for the amount of space the bubble was taking up.
When you first bleed your loop it looks clear and to be free of air, but in reality its not at all, over time as the liquid flows it makes your liquid more concentrated. (concentrated meaning free of air in this case.)
That is true but with Tygon tubing that is very very slight.
All depends on what tubing you are using.
With tygon and laboratory grade tubing this permeation is very very very slight if not even measurable in some cases.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 22, 2007, 06:56 PM
sswilson's Avatar
After finding myself short on 3/8" tubing for a project, I remembered that I had 7' of 3/8" ID fuel line (black with fiber). Wouldn't that be pretty well non-porous as well? And second to that.... any reason why it couldn't be used in a water loop?
It wouldn't fully kink, and it looks like even when partially kinked, the hole just becomes elongated rather than pinched which should allow for fairly good flow without too much restriction.
What do you think?
Old October 22, 2007, 07:22 PM
Apollo4g's Avatar
What do you think?
That fuel tubing is great with those interwoven fibers inside it right?
I used that for a whole loop once, like you said it prevents kinks and is really hard to kink that tubing.
But after a while i just got sick of the look.
Nothing wrong with using that tubing at all.
Some people prefer it to tygon,masterkleer and the other tubings normally used.
Old October 23, 2007, 07:32 AM
Norprene's porosity is 1/5 of Vinyl tubing, according to Swiftech's site
Friend's PC, Tygon throughout:
[H]ard|Forum - View Single Post - New and Improved Watercooling Sticky - Post Your Systems Here
Pretty disgusting how the Dexcool condensed as the water evap'd out of the loop, giving it a murky colour
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 11:35 AM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
