Old October 23, 2007, 10:57 AM
Apollo4g's Avatar
Originally Posted by YugenM View Post
Norprene's porosity is 1/5 of Vinyl tubing, according to Swiftech's site
Friend's PC, Tygon throughout:
[H]ard|Forum - View Single Post - New and Improved Watercooling Sticky - Post Your Systems Here
Pretty disgusting how the Dexcool condensed as the water evap'd out of the loop, giving it a murky colour
It also depends on the liquid contentment of what chemicals.
Also take not the on the outside tygon is a little sticky, so dust and other micro filaments stick to it
and make it look much more murky than it is.
If you clean out that coolant from the inside, clean the outside wall of the tygon with some alcohol and cloth.
I guarantee it will look much clearer.
Its mainly the liquid that turns murky and not the tubing itself. Yes the tubing does get coated by the chemicals in the loop but seaping in through the tygon, that is very very slight like i mentioned before.
It could be seaping out from other areas and components.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 11:35 AM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
