Old February 23, 2010, 05:19 PM
MarkOne's Avatar
Default What additive are you using in your water
the title say everything......
Old February 23, 2010, 05:23 PM
AmuseMe's Avatar
Pure distilled and silver.
Old February 23, 2010, 05:36 PM
+1
Old February 23, 2010, 06:16 PM
gingerbee's Avatar
using feser right know but have used everything from feser,pure distalled. or distalled with many types of anti freeze you know good old ethylene glycol does the trick
Old February 23, 2010, 06:22 PM
Dazmode's Avatar
Dazmode Protector is all you need.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old February 23, 2010, 06:42 PM
chrisk's Avatar
Folding Captain
Feser in one rig, Dazmode-Distilled in the other.
Fold for team #54196
Old February 23, 2010, 06:50 PM
lowfat's Avatar
RO water w/ no additives. It has been the only thing I've used in the past 4-5 years. My very first build was the only time I added anything to the loop. And it was highlighter.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old February 23, 2010, 06:59 PM
OHPC
Guest
Posts: n/a
When I ran water all I used was distilled and a silver coil.
Old February 23, 2010, 07:00 PM
Babrbarossa's Avatar
I use swiftech HydrX as recommended by Coolit for my Boreas 12 since I've added a GPU block and changed the CPU block to a HK- unavoidably a mixed metal loop with those boreas 12s and Coolit says that HydrX suppresses any corrosion. Is the Daz protectant a similar formula? If so I'll switch.
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old February 23, 2010, 07:01 PM
MarkOne's Avatar
do you buy the water or you do it your self , I have a RO unit here + a cartridge to remove the silicate ( cause of the algae) I use it for my salt water aquarium
someone have ever use a UV filter ?
What is in the water?! encorp Off Topic 44 February 17, 2010 01:03 PM
Bike won't start after using NOS fuel additive CTA Off Topic 17 May 24, 2009 03:42 PM
Water is the best? magictorch Water Cooling 16 January 25, 2009 06:41 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 11:57 AM
