<~----> What additive are you using in your water - Page 5 - Hardware Canucks
  #41 (permalink)
Old March 5, 2010, 04:07 PM
Jackquelegs's Avatar
It dehydrates the acrylic, causing it crack
Iapetos
Zephyranthes
  #42 (permalink)
Old March 7, 2010, 10:36 AM
I've found that Feser One dyes gunk up your look if you keep it longer than a year. I had that in my old loop and i had to clean out everything and brush it down.
I currently use PT_Nuke PHN and Distilled water I bought from a local water shop. They claim it to be 99.9% distilled, which is basically hydrogen + oxygen, with no additives. I drain my loop every 6 months and wash it out with diluted vinegar every *other* 6 months.
I've taken apart my loop, and have found it to have minimal to no gunk.
  #43 (permalink)
Old March 8, 2010, 01:33 AM
Lima's Avatar
Originally Posted by Jackquelegs View Post
True Silver? Yes. Shining Silver? no
Good. I had bought a couple BP True silver barbs so, no need for silver wire now.
Thanks
  #44 (permalink)
Old March 8, 2010, 07:18 AM
Dazmode's Avatar
That is why it is recommended to maintain your loop every 9-12 months.
Orange Build: Final Video
HTPC Build: Final Video
  #45 (permalink)
Old March 8, 2010, 10:54 AM
Levesque's Avatar
I know distilled water is dirt cheap, but demineralized water will do the same job if you can't find some. After 1 or 2 weeks, every loop out there will become conductive anyway with ions circulating in higher quantities after a while. So no need to get obsessed with finding distilled water absolutely. :)
  #46 (permalink)
Old March 8, 2010, 03:12 PM
homer98's Avatar
Do highlighters affect the water at all? say you have distilled water + PT Nuke, then add a colouring agent, does that negate anything from the mixture?
What is in the water?! encorp Off Topic 44 February 17, 2010 12:03 PM
Bike won't start after using NOS fuel additive CTA Off Topic 17 May 24, 2009 02:42 PM
Water is the best? magictorch Water Cooling 16 January 25, 2009 05:41 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 04:34 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
