  #21 (permalink)
Old March 3, 2010, 01:33 PM
matsta31's Avatar
distillated water + petra nuke.
Sold hardware again.....
Currently using WHS hardware....
  #22 (permalink)
Old March 3, 2010, 10:05 PM
homer98's Avatar
Hey all, new to watercooling, but when using distilled water, why do you need Anti-Freeze or this "Silver" you speak of?? why need to mix certain things?
  #23 (permalink)
Old March 3, 2010, 10:59 PM
Jackquelegs's Avatar
Leave a cup of water out in the open for a while, see what happens Silver is biocide
Galvanic corrosion - Wikipedia, the free encyclopedia
Anti freeze, or any ethylene glycol solution prevents these corrosions to a certain extent..but only a certain extent
Iapetos
Zephyranthes
  #24 (permalink)
Old March 4, 2010, 08:39 AM
Levesque's Avatar
I use distilled water + 1 drop per liter of water of Lugol Solution (iodine). 3$ for a 100ml bottle. And I have a twisted 8'' long 18 GA .999 pure silver wire at the bottom of all my reservoirs. Around 6$ for a 24'' wire shipped from ebay. :)
Water is crystal clear. I just cleaned a 1 year old loop, and everything was sparkling clean everywhere. :)
Every 3 to 6 months, I just put a new drop of Lugol in each loop.
Iodine + copper + silver ions are a pretty powerful algicide/biocide combination. :)
BTW, Petra Nuke is just copper sulfate. And you can make your own silver kill coil for alot less $ then they charge in watercooling stores. :)
  #25 (permalink)
Old March 4, 2010, 09:59 AM
homer98's Avatar
So you don't need to change the water very often if you have Silver and some sort of anti-freeze or ethylene glycol?
  #26 (permalink)
Old March 4, 2010, 12:00 PM
Lima's Avatar
Do you still have a link to that Ebay seller? And, out of curiosity mostly, how much does the Iodine affect the waters color?
I have HydrX and distilled water in my loop presently but, planning a change to distilled water + silver.
  #27 (permalink)
Old March 4, 2010, 12:10 PM
Iodine is brown. But if you use trace amounts of it, it doesn't affect the coloring. If your loop changes color, you're doing it wrong
Iapetos
Zephyranthes
  #28 (permalink)
Old March 4, 2010, 12:45 PM
matsta31's Avatar
So, distilled + silver, would mean I dont have nothing else to put in ?
  #29 (permalink)
Old March 4, 2010, 12:54 PM
Lima's Avatar
Good to know.
On another note. I have BP silver fittings, is one per loop gonna be enough?
  #30 (permalink)
Old March 4, 2010, 02:38 PM
Levesque's Avatar
It was more then 1 year ago, so I don't remember. Just type ''.999 pure silver wire'' on ebay.ca and make your choice. :)
I put 1 drop in 1 liter of water. It's almost an ''homeomagic'' concentration, huh I mean homeopathic... 8 drops in 4 liters of distilled water won't affect the ''color'' of the water. :)
What is in the water?! encorp Off Topic 44 February 17, 2010 01:03 PM
Bike won't start after using NOS fuel additive CTA Off Topic 17 May 24, 2009 02:42 PM
Water is the best? magictorch Water Cooling 16 January 25, 2009 06:41 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
