-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   Thermal pads (https://www.hardwarecanucks.com/forum/water-cooling/29155-thermal-pads.html)
Chromey February 22, 2010 03:59 PM
Thermal pads
I need to replace the Shit pads that HEatkiller sent with thier GPU block, WHere can i buy them.
Dazmode February 22, 2010 09:34 PM
Khm.... Khm...:whistle:
Liu Kang February 22, 2010 09:52 PM
Don't blame you, the HK ones are pretty shitty. Dazmode sells the EK pads... not expensive either.
Chromey February 23, 2010 05:36 AM
I didnt know if Daz pads would work, But After measureing, Ill place my order.
Dazmode February 23, 2010 02:40 PM
There is two thickness sizes: 0.5 and 1mm. HK supplies 0.5mm with GPU blocks.
