Old February 21, 2010, 03:19 PM
aCid888*'s Avatar
Exclamation Koolance CPU-360 Caompatability Issues!
UPDATE: The issue has been resolved, read HERE.
This is a direct quote from TechPowerUp! regarding the new block from Koolance that has issues with X58 & P55 Gigabyte boards.
To put it in to context he was getting a huge temperature increase and couldn't figure out why....that is until he had a closer look.
Originally Posted by HammerON @ TechPowerUp!
Well after spending too much money to replace a perfectly good Apogee GTZ SE, I found that the Koolance wb doesn't fit my board. The capacitors (or whatever they are) on the I/O side of the CPU are keeping the block from making contact with the CPU:(
So just fair warning for any of you who were going to try the Koolance CPU-360 on their Gigabyte X58 UD4P. It states on Koolance's website that it is visually confirmed for this board.
Anyways I am now going to try and see if it will work on my EVGA X58 SLI LE board. Will post back with temps (hopefully)>
I wanted to post this here to avoid people ordering this block for the GB boards under the assumption it will work (like they say it would!) when it actually doesn't.
Hers (pInky):
945ES @ 3.92GHz (1.5v) - Lapped Fuzion v1
MCP-355/XSPC Top + Black Ice Extreme 360
Asus M3A79-T Deluxe 790FX (MX-2 NB + SB)
2x2GB G.Skill Pi Black @ 900MHz 444-12
PNY "XLR8" 9800GX2 @ 704/2202/1760
Seagate 500GB + XP SP3
22" Acer P223w @ 1680x1050
Modded Lian Li PC-60F
SB Audigy 2 w/ Heatsink
Old February 21, 2010, 03:32 PM
MarkOne's Avatar
you have to be dam nood to install a cooler on the capacitors , I order a koolance , I will see how it fit on my board
matsta31's Avatar
Is it me, or it seems there is lots of thermal paste on the CPU ?
But good to know.
Sold hardware again.....
Currently using WHS hardware....
Old February 21, 2010, 03:34 PM
MarkOne's Avatar
But good to know.
Ya it just confirm my nood statement. and yes I start to worry about fitting it to my board
edit : it will may not fit on my Asus but on my Evga ... the caps ar not touching the cpu socket like the giga on the pics , I think it will fit the Asus Formula III ( finger crossed)
Old February 21, 2010, 03:51 PM
aCid888*'s Avatar
This should fit other boards...its just because Gigabyte decided to pile on caps really close to the socket.
Also, that is a lot of TIM.
Hers (pInky):
Old February 21, 2010, 03:56 PM
MarkOne's Avatar
I hope so I just pay $ 144.32 US for one yesterday
Part # Product Description QtyPriceTotalex-blc-728Koolance CPU-360 Liquid Cooling Extreme CPU Block (No Fittings) 1$89.99$89.99Item Total: $89.99Shipping:$24.33Tax:$0.00Grand Total: $114.32
Old February 21, 2010, 04:00 PM
aCid888*'s Avatar
If it doesn't I will swap you my 345 for the 360.
On a more serious side.....I hate when they say something works and it doesn't.......I dont expect this from Koolance as they are usually A+ when it comes to being honest about their products.
Hers (pInky):
Old February 21, 2010, 04:06 PM
MarkOne's Avatar
The guy who post on the other board say that on Koolance they show is x58-UD4P in the list , unless they have made change recently, I see no such board on the list
Old February 21, 2010, 04:13 PM
aCid888*'s Avatar
I pulled this from the same thread as the original post:
It shows the compatibility of Koolance products for his UD4P.
It also appears that the EVGA X58 SLI LE and X58 Rampage Gene II has issues with this block.
Hers (pInky):
Old February 21, 2010, 04:31 PM
MarkOne's Avatar
so they remove the UD4P now
go see
Product Selection Wizard - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
[FS] Koolance CPU-350AC (Acrylic) Apollo4g Buy/Sell & Trade 28 October 15, 2009 01:31 AM
Upgrading issues, what vid card, cpu?! Andy New Builds 10 September 25, 2008 12:43 AM
Please take a look(cpu -ram issues)any help will be apreciated. evzonas CPU's and Motherboards 12 August 11, 2008 01:50 PM
Discussion Thread for Koolance CPU-330 review Misoprostol Water Cooling 35 April 20, 2008 06:23 PM
