  #31 (permalink)
Old February 22, 2010, 02:29 PM
MarkOne's Avatar
the problem is not Koolance, it's Gigabyte that make the thing imposible, those caps are to close to the cpu socket
  #32 (permalink)
Old February 22, 2010, 08:05 PM
lowfat's Avatar
And Koolance had absolutely no reason to make the base that irregular shape. Nor is there a reason to extent over the IHS.
Mael
Big Lian Li
Forever Alone
  #33 (permalink)
Old February 22, 2010, 08:24 PM
MarkOne's Avatar
I will see when I gone receive mine, but this a pic of under the block , look to me they want to use a round O ring
  #34 (permalink)
Old February 22, 2010, 08:26 PM
AmuseMe's Avatar
*Cough* *Cough* HK 3.0 Clone. New Koolance CPU-360 Waterblock - Overclock.net - Overclocking.net Im sure more of you noticed, also take a read on the first page
  #35 (permalink)
Old February 22, 2010, 09:11 PM
aCid888*'s Avatar
Who cares if its a clone or not??
The OCZ Vanquisher is a "clone" of the HDT-1283 but people still didn't mind as its all about choice.
Personally, I don't like the way HK blocks look and much prefer this block.....someone else may not agree but there are two products out there that perform well and look good.
I just want people to be informed about issues with products before they go wasting their money on something that doesn't work.
It's also nice to see someone quoted my post word for word over at another forum.
Hers (pInky):
945ES @ 3.92GHz (1.5v) - Lapped Fuzion v1
MCP-355/XSPC Top + Black Ice Extreme 360
Asus M3A79-T Deluxe 790FX (MX-2 NB + SB)
2x2GB G.Skill Pi Black @ 900MHz 444-12
PNY "XLR8" 9800GX2 @ 704/2202/1760
Seagate 500GB + XP SP3
22" Acer P223w @ 1680x1050
Modded Lian Li PC-60F
SB Audigy 2 w/ Heatsink
  #36 (permalink)
Old February 23, 2010, 03:23 PM
AmuseMe's Avatar
Fair enough. My fault with going off topic. But I must agree with Space Pope over there "I just don't like companies reverse engineering other peoples products." I totally agree with him, than again almost every company copies another one some way or another - looks like I just need to get use to this
Hey Koolance - is it made out of aluminum?
  #37 (permalink)
Old February 23, 2010, 04:05 PM
MarkOne's Avatar
The CPU-360 contains a copper cold plate with brass top. As with all Koolance products, nickel plating is added to improve corrosion resistance
Copper Cold Plate, Brass Top, Nickel-Plating, Stainless Steel Jet Plate
  #38 (permalink)
Old February 23, 2010, 04:25 PM
aCid888*'s Avatar
No worry for going off topic......it happens in every thread.
I'd sooner have a winning design copied (HK?) than a company putting out crap they have tried to design and make work well but have failed.
On a good note, Koolance have RMAed HammerON's block and are looking into this case.
For the time being, DO NOT ORDER this block for your Gigabyte P55/X58 board....or any other board that has caps all around the CPU socket.
The real issue here is GB and their stupid board design that does indeed violate the space around the socket.....add in the fact that Koolance decided to make a block with a big, odd shaped block and it makes for this issue.
Hers (pInky):
  #39 (permalink)
Old February 23, 2010, 05:54 PM
aCid888*'s Avatar
Exclamation
UPDATE!
Originally Posted by (Koolance)Tim
We are currently investigating reports of mounting conflicts on some Gigabyte X58 motherboards with the CPU-360. Although Gigabyte seems to be the main issue, we will be looking into other brands.
The problem relates to capacitors which are too close to the CPU socket. The CPU-360 is 59mm at the widest part of the cold plate. There needs to be at least 2.65mm of clearance between nearby rows of capacitors and the closest edge of the CPU socket. Updates will be posted here once we know more, including potential workarounds and/or modifications to the CPU-360.
Pictures of an ASUS Rampage II GENE (with the CPU-360 mounted properly) are below.
Hers (pInky):
  #40 (permalink)
Old February 23, 2010, 06:19 PM
Dazmode's Avatar
Obviously Koolance didn't do homework. GA is big enough to be on the check list.
Orange Build: Final Video
HTPC Build: Final Video
[FS] Koolance CPU-350AC (Acrylic) Apollo4g Buy/Sell & Trade 28 October 15, 2009 12:31 AM
Upgrading issues, what vid card, cpu?! Andy New Builds 10 September 24, 2008 11:43 PM
Please take a look(cpu -ram issues)any help will be apreciated. evzonas CPU's and Motherboards 12 August 11, 2008 12:50 PM
Discussion Thread for Koolance CPU-330 review Misoprostol Water Cooling 35 April 20, 2008 05:23 PM
