Old February 22, 2010, 04:56 PM
Originally Posted by Chromey View Post
Look @ my wiring... enough said.
Sorry man.. really is proving nothing.
As previously stated its not a case... thats a tech bench.
A case has 6 enclosed sides.
Old February 22, 2010, 05:01 PM
A case has 6 enclosed sides, Proof?
Old February 22, 2010, 05:05 PM
Stilling looking for the rule that sats it has to be 6 sides.
Case 1
Definition: A box, sheath, or covering; as, a case for holding goods; a case for spectacles; the case of a watch; the case (capsule) of a cartridge; a case (cover) for a book.
Case 2
Definition: A box and its contents; the quantity contained in a box; as, a case of goods; a case of instruments.
Case 3
Definition: A shallow tray divided into compartments or "boxes" for holding type.
Case 4
Definition: An inclosing frame; a casing; as, a door case; a window case.
Case 5
Definition: A small fissure which admits water to the workings.
Case 6
Definition: To cover or protect with, or as with, a case; to inclose.
Case 7
Definition: To strip the skin from; as, to case a box.
Case 8
Definition: Chance; accident; hap; opportunity.
Case 9
Definition: That which befalls, comes, or happens; an event; an instance; a circumstance, or all the circumstances; condition; state of things; affair; as, a strange case; a case of injustice; the case of the Indian tribes.
Case 10
Definition: A patient under treatment; an instance of sickness or injury; as, ten cases of fever; also, the history of a disease or injury.
Case 11
Definition: The matters of fact or conditions involved in a suit, as distinguished from the questions of law; a suit or action at law; a cause.
Case 12
Definition: One of the forms, or the inflections or changes of form, of a noun, pronoun, or adjective, which indicate its relation to other words, and in the aggregate constitute its declension; the relation which a noun or pronoun sustains to some other word.
Case 13
Definition: To propose hypothetical cases.
case 14
Definition: a comprehensive term for any proceeding in a court of law whereby an individual seeks a legal remedy; "the family brought suit against the landlord"
case 15
Definition: a portable container for carrying several objects; "the musicians left their instrument cases backstage"
case 16
Definition: a glass container used to store and display items in a shop or museum or home
case 17
Definition: bed linen consisting of a cover for a pillow; "the burglar carried his loot in a pillowcase"
case 18
Definition: the enclosing frame around a door or window opening; "the casings had rotted away and had to be replaced"
case 19
Definition: the housing or outer covering of something; "the clock has a walnut case"
case 20
Definition: an enveloping structure or covering enclosing an animal or plant organ or part
case 21
Definition: the actual state of things; "that was not the case"
case 22
Definition: nouns or pronouns or adjectives (often marked by inflection) related in some way to other words in a sentence
case 23
Definition: a statement of facts and reasons used to support an argument; "he stated his case clearly"
case 24
Definition: a problem requiring investigation; "Perry Mason solved the case of the missing heir"
case 25
Definition: an occurrence of something; "it was a case of bad judgment"; "another instance occurred yesterday"; "but there is always the famous example of the Smiths"
case 26
Definition: a person requiring professional services; "a typical case was the suburban housewife described by a marriage counselor"
case 27
Definition: a person of a specified kind (usually with many eccentricities); "a real character"; "a strange character"; "a friendly eccentric"; "the capable type"; "a mental case"
case 28
Definition: a person who is subjected to experimental or other observational procedures; someone who is an object of investigation; "the subjects for this investigation were selected randomly"; "the cases that we studied were drawn from two different communities"
case 29
Definition: the quantity contained in a case
case 30
Definition: a special set of circumstances; "in that event, the first possibility is excluded"; "it may rain in which case the picnic will be canceled"
case 31
Definition: a specific state of mind that is temporary; "a case of the jitters"
case 32
Definition: enclose in, or as if in, a case; "my feet were encased in mud"
case 33
Definition: look over, usually with the intention to rob; "They men cased the housed"
Old February 22, 2010, 05:09 PM
MarkOne's Avatar
this is ridiculous , Daz ask a good question here
I gone give you a big con about acrylic....they crack if you tight something too much,
Old February 22, 2010, 05:12 PM
Dazmode's Avatar
Still want one to try.
I doubt it has more heat build up then any other material with proper ventilation.
Orange Build: Final Video
HTPC Build: Final Video
Old February 22, 2010, 05:19 PM
Liu Kang's Avatar
They are ugly. Does that count as a con, or is that too subjective? :)
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old February 22, 2010, 05:23 PM
headsh0t's Avatar
Chromey your case would be like if I took off my side panel and laid it on it's side. It's not enclosed is what the point was. Looks pretty sick though.
Old February 22, 2010, 05:34 PM
MarkOne's Avatar
Read your Asus board instruction, they say to use the other heatsink on the Mosfet Cooler, ( the one with long fins ) when you use WC ...
  #19 (permalink)
Old February 22, 2010, 05:47 PM
Shit, Thanks MArk I missed thats... Do you think its over heating?
Ill do it now.
  #20 (permalink)
Old February 22, 2010, 05:50 PM
MarkOne's Avatar
Ill do it now.
I will leave the one you have in place and put the squirel fan on it. don't kow if you overheat, but why take chance
Cowboy's Acrylic PC - It's finally HERE! Cowboy Case Mods, Worklog & Gallery 56 September 19, 2009 12:56 PM
Where to buy acrylic in Vancouver Phobia Off Topic 7 July 26, 2009 12:26 AM
Acrylic case EMI/static discharge concerns serenity Cases 8 October 9, 2008 11:06 PM
acrylic panels? moditir Cases 13 September 22, 2007 12:30 AM
Sunbeamtech UFO Acrylic Cube Case review by ProClockers Babrbarossa Reviews & Articles from the Web 0 April 10, 2007 06:18 AM
