Old February 15, 2010, 08:11 PM
bkh2's Avatar
Default Need some help with placement
Hey HWC, I'm kinda planning/hoping to W/C my GPU, but I would like to add another radiator in the loop. Here's a couple links to what it looks like now:
http://www.sfu.ca/~bkh2/Computer/P2150137.JPG
http://www.sfu.ca/~bkh2/Computer/P2150138.JPG
In case you're wondering, I'm using 5/8" ID tubing to and from the pump and 1/2" tubing for everything else, which is why I'm using those copper fittings. Excuse the dust, but I'm thinking about turning the res and pump 90 degrees about the y axis and mount them on the mobo tray. I don't know if that makes sense, but I'd also like to place a single radiator on the bottom, pulling air out of the case. In summary:
Reservoir > Pump > Single Radiator > GPU > Triple Radiator > CPU > Reservoir
So perhaps I position the single radiator with barbs closest to the HDD cage, then the outlet of that radiator to the GPU?
Again, this is purely hypothetical. I'm waiting on Fermi and a nice water block
Old February 15, 2010, 09:30 PM
Jackquelegs's Avatar
You definitely do not need another radiator. A triple is more than enough for what you have.
Pump>CPU>GPU>Rad>Res>Pump
is my recommendation. Grab a pump top for the 655
Or if you don't want any mods to the pump
Pump>GPU>CPU>Rad>Res>Pump
This way you can simply add a GPU block without modifying the pump
Iapetos
Zephyranthes
Old February 15, 2010, 09:37 PM
bkh2's Avatar
I've read that the water leaving a water block is not significantly hotter, so it should be fine, but I don't know... I should take your guys' word for it since you have much more experience. As for placement for my pump and res, any suggestions? The tube coming from the pump to the rad blocks be from adding a big second card. I was able to crossfire two 3870's but I wasn't able to get two gtx 275's in there.
Old February 15, 2010, 09:53 PM
You could always mount the pump at the bottom, and the res on the back
http://dl.dropbox.com/u/1372434/P2150137.JPG
Iapetos
Zephyranthes
Old February 16, 2010, 12:00 PM
Yup yup like Jackquel shows ^^.. I have mine setup with a similar setup, let me see if I can some pics here, camera's at home.. Only problem in putting the res there, is that the are does become tight in space, especially taking out the video card becomes sort of a challenge with tubes in the way.
Although if you want you could leave the placement as it is, and simply take out the tube going from cpu to res, and move it to cpu to gpu in, and then another tube from gpu out to res.
Old February 16, 2010, 12:20 PM
bkh2's Avatar
I had originally planned to populate the bottom grill with another 120mm fan, then thought about adding a single rad there, but since you guys suggest against it, I plan to place a 120mm fan there haha. Therefore I can't exactly mount the pump right on the bottom without obstructing the fan. Also, if I put the reservoir where Jackquelegs suggested, will that block the side panel 250mm fan? Maybe I could move the res up to the ram area... sigh... There's nothing worse than getting limited to changes because a tube is in the way or there is just the smallest obstruction ever in the way.
speaker type and placement bissa Off Topic 41 October 21, 2009 11:38 AM
Bad Review Placement! 3 of 7 Off Topic 8 August 27, 2009 08:39 PM
UV Light placement JD Cases 0 August 19, 2009 07:08 PM
Cooling Parts Placement miggs78 Cases 33 August 15, 2008 06:36 PM
placement of barbs flybye Water Cooling 2 February 13, 2008 02:53 PM
