Old February 14, 2010, 07:07 PM
Fudd Rucker's Avatar
Default CPU to GPU?
Im planning on overhauling my watercooling system and was wondering if it would be a bad idea to run directly from the cpu to the gpu then out to the radiators? Or would the water be too hot from the cpu therefore negating the purpose of watercooling the gpu?
Im planning on using 4 x yate loon + 2 x sflex 1600rpm fans with a TFC Xchanger 240 and an MCR220 in a giant pushpull fan sandwich. The CPU block is an EK supreme LT and the VGA block will be an EK 5870 full coverage block. The line is running 1/2" tubing and using an MCP655. I would like to cram the whole unit into a custom box later on with everything inside the external custom box and just lines running in and out.
Swiftech MCP-655 | EK Supreme Acryllic
XSPC 360 | DD Dual 5.25"
Primochill 1/2" Tubing | 3 x 38mm Kaze 3000rpm
EK Nickel GTX 480
Old February 14, 2010, 07:39 PM
Jackquelegs's Avatar
Water doesn't transfer 100% of the heat from the CPU block to itself. The water out of a CPU block does not have the same temperature as the CPU block. Likely it's going to be around 5C above the ambient temperature if your flow is good. Hence, it's not a huge impact by having CPU - GPU.
So with CPU-GPU you'll see a slightly higher temp on the GPU, however it's almost negligible since the temps on a card is going to be excellent with water anyways.
Iapetos
Zephyranthes
Old February 14, 2010, 07:46 PM
The order of the loop really doesn't make a difference, so you'll be fine if you do that.
Old February 14, 2010, 08:15 PM
chrisk's Avatar
Folding Captain
I was wondering the same thing a while back. From what I was able to find, after a few minutes the temp of the whole loop evens out as the water is circulated.
Fold for team #54196
Old February 14, 2010, 08:31 PM
Thats good to know, Im fairly confident the 2 radiators should net me excellent temps for both CPU and GPU. The gpu cooling is maily out of necessity than performance as the referance 5870s are ridcilously loud and noisy. But I have gotten this sucker to run @ 4.4ghz though, but couldnt keep temps within range so thats my goal.I would also like to see 1000mhz core/1500mhz mem speeds on the video card as well while having it run dead silent.
EK Nickel GTX 480
Old February 15, 2010, 01:30 AM
biff's Avatar
A clean layout is more important than order. The temp difference as the coolant passes through the CPU block should be very minimal, much less than anything that would make a difference to a GPU.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old March 7, 2010, 11:38 AM
keep in mind your GPU won't lose performance as much if the temps are high, compared to a CPU
Old March 7, 2010, 11:44 AM
gingerbee's Avatar
it's all about ambient and your rad.
Old March 7, 2010, 12:27 PM
Temperatures don't affect performance at all, regardless of whether you're dealing with a CPU or GPU.
Old March 8, 2010, 08:10 AM
Dazmode's Avatar
I'm with Biff. +1
I have single loop myself: ...CPU - chipset - GPU1 -GPU2 -.... Works great.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
CPU and gpu charts MarkOne HardwareCanucks F@H Team 13 December 14, 2009 04:42 PM
[FS] CPU and GPU+FC waterblock. Lima Buy/Sell & Trade 38 August 21, 2009 01:09 AM
Bottleneck - GPU or CPU? mattydies Video Cards 15 July 6, 2009 11:32 PM
Folding on GPU+CPU Jonwall HardwareCanucks F@H Team 2 March 30, 2009 02:40 PM
Cpu, Gpu or what? upgrade? phil3_66666 CPU's and Motherboards 12 March 14, 2009 06:54 PM
