Old October 13, 2007, 07:18 PM
Cptn Vortex's Avatar
Here's my system, I take bad pics. Anyway, this is the H20 220 Apex Ultra Plus kit. Works awesome, looks awesome.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old October 13, 2007, 08:41 PM
lcdguy's Avatar
Originally Posted by Babrbarossa View Post
I would get one of these kits right now...great components (chosen by Linus I assume) and it seems like the only way to get your hands on a thermochill PA 120.2 right now. Grab an MCW60 or a full coverage waterblock for your GPU as well (don't forget the mosfet heatsinks and the mcw14s for the video memory if you go the mcw60 route). Some might argue that the 2X120mm radiator is not enough to do both your CPU and GPU, but these are GREAT radiators, and while I'm not sure as I've never actually used one, I think it would be enough- anyone else have a say on this?
Here's a worklog and a bit of a guide for H2O noobs that I made when I first ventured into the water waaaaay back in March ;-)
I agree with this, Buy that kit. it's basically the same system i have bar 2 differences and is less than 1/2 of what i paid.
Old October 13, 2007, 11:58 PM
Apollo4g's Avatar
Plus 1 for the ultimate 240 kit form NCIX.
Great kit with some great parts!
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 14, 2007, 07:13 AM
3.0charlie's Avatar
Those Quads put out so much heat. That PA120.2 might do the trick though, for a complete wc system. I'm supposed to receive my dual rad (the Swiftech model) on Tuesday - I'll compare the single rad to that new dual later that night.
Hydro-Quebec is salivating...
Old October 14, 2007, 08:21 AM
is that the one from Swiftech?? the 300 dollar kit?
oppps sorry, I saw its Swiftech in your sig..... sorry Awesome photos man... would love to see more of the rad in the top of the case and such.... I could look at them all day long!!!!!!!!
Wheres rhe 8800?? I cant see it in the photo. ALso, if its in the photo, is the power connection plugged in. And one more question... is the GPU watercooled?? Hard to tell from the photo (with my eyes)
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old October 14, 2007, 08:48 AM
Shadowmeph's Avatar
I have a question what is the difference between these two rads HW Labs Black Ice GT Stealth 360 Triple 120MM Water Cooling Radiator Black 1/2IN Barbs and this one ( besides the price)
HW Labs Black Ice GT Xtreme 360 Triple 120MM Water Cooling Radiator Black 1/2IN Barbs
I am also wondering if this size rad would fit in a gigabyte aurora 570 case ( preferably in the bottom)?
Old October 14, 2007, 09:09 AM
Babrbarossa's Avatar
The stealth is thinner and has less cooling surface area and therefore does not cool as well, but on the plus side, it has less air resistance and so doesn't need a fan with as much oomph as the GTX does. The GTX is best used with 38 mm panaflo type fans so when you get the whole thing together, you're looking at almost ten cm of thickness, so you might need to consider that when planning your layout. I have the GTX installed in a p180 and am very happy with it.
Old October 14, 2007, 09:52 PM
Here is how I put the RAD in the top of the case. Bad pics as usual. Also, yes, I am definitely cooling that 8800GTX. And it stays nice and cool, under 52 degrees full load, with a nice OC.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
  #19 (permalink)
Old October 15, 2007, 11:05 AM
Thanks guys, if i have any more questions i will ask later......
Thinking About Watercooling - Where To Buy? ChuckleBrother Water Cooling 17 March 24, 2008 09:30 PM
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Help With Watercooling! Gasp! llama_egg Water Cooling 27 December 8, 2007 10:06 AM
Watercooling GPU's/CPU/kit frosty Water Cooling 55 October 23, 2007 06:19 PM
