  #641 (permalink)
Old December 17, 2014, 03:30 PM
fishingfanatic's Avatar
Smile Water Cooling
Well I just found out I don't have to buy another cpu block, as EK confirmed the rumours that most of their blocks are compatible with the Haswell E, so I can use my current one, yay
FF
  #642 (permalink)
Old May 13, 2015, 10:10 AM
Hooded's Avatar
Default Gentle Typhoon Performance Radiator Fan - 2150rpm, 68cfm - Black Edition
The only place on the planet with stock!
  #643 (permalink)
Old May 13, 2015, 10:39 AM
Dazmode's Avatar
Thank you Hooded for posting.
Fans will be also available in UK at Mayhems store.
Orange Build: Final Video
HTPC Build: Final Video
  #644 (permalink)
Old May 21, 2015, 07:08 PM
CTA's Avatar
CTA CTA is offline
i tried to pm and email and i dont receive any email... i kinda found this weird...
anyone of you know about the radiator from darkside then please... i really need to know before i order...
i want to know if most darkside radiator is based on the rebrand or own design... i only found answers at this http://www.hardwarecanucks.com/forum...radiators.html about LP but i am looking at pxm360... it looks like Thermochill pa120 radiator...
  #645 (permalink)
Old May 22, 2015, 07:10 AM
AmuseMe's Avatar
I should really get back to making my homemade radiators again. Dazmode, as well as others, might remember me posting about them some years back, when I used to build industrial size radiators for a small local business.
  #646 (permalink)
Old October 2, 2018, 03:57 PM
BrainEater's Avatar
Just wanted to check in here, since the last post was 2015.
Dazmode you still in business?
I'm looking for some white watercooling hose.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
  #647 (permalink)
Old October 2, 2018, 05:26 PM
gingerbee's Avatar
yup he is https://www.dazmode.com/store/
ya daz i tried to send you a message to see if your store takes visa debt thanks for any answer is you check here at all
  #648 (permalink)
Old October 2, 2018, 05:47 PM
sswilson's Avatar
There was a note that showed up when I visited the site earlier that referred to Daz being unavailable until the 12'th due to his Brother passing away. (My condolences to you and your family if you see this in here Daz).
  #649 (permalink)
Old November 19, 2018, 05:31 PM
BrainEater's Avatar
Thanks Daz !
Got my pump and white hose.
I like the hose for sure.
Merry Christmas to Dazmode and all! Lpfan4ever Off Topic 13 December 18, 2009 11:01 AM
Good News and Bad News. need some advice. arekieh Troubleshooting 7 November 23, 2008 10:24 AM
AMD: Want the good news or the bad news first? Cheator CPU's and Motherboards 7 July 20, 2008 08:03 PM
