  #611 (permalink)
Old January 14, 2014, 02:51 PM
Dazmode's Avatar
My store do not sell those things well, so unlikely. Everybody were screaming about Enerdyne and as soon as stock on it... silence.
Orange Build: Final Video
HTPC Build: Final Video
  #612 (permalink)
Old April 9, 2014, 04:24 PM
marc_0053's Avatar
Received my 9 x gentle typhoon ap-45 today :)
Fast shipping!!
  #613 (permalink)
Old April 10, 2014, 05:48 AM
Dazmode's Avatar
good fans, I have 11 myself :)
  #614 (permalink)
Old April 10, 2014, 08:05 PM
rjbarker's Avatar
Hi Daz....love your site and all your WC info...although I have not taken the jump I am certainly close to taking theplunge, actually put together $700 work of goodies in my basket on your site last night.
Couple of quick noob Bob Zone questions re: tubing and fittings and EKWB for my 2 x Evga GTX 780Ti SC Reference:
2. Any idea when you'll have stock EKWB Back plates for Evga 780Ti SC Reference Cards?
3. Looking at this DS Photon 170 Combo ...your thoughts? https://www.dazmode.com/store/produc...oirpump-combo/
Specs in my Sig, lots of room to play with in my 900D Case. Going to replace the Swiftech H320 Cooler with a proper CPU WB but utilize the H320 Rad up top (presently set up with 6 fans in push / pull), add another 360mm Rad to front of the case and of course WB's for my 780Ti SLi setup. Seem alright?
Now, not sure which is the best way to go for SLi Watercooling fittings between my 2 GPU's. On my RIVE Board I run 1st Card in the top Slot and second Card in the 3rd Slot, (obviously on air I like the spacing), now on water I would like to keep the same spacing so I can continue to use my cool Evga Tri SLi LED Bridge, so which WC Bridge would you recommend?
EDIT: So just researching and it looks like a Triple Size Bridge for 2 Cards or Triple Size Bridge for 3 Cards and a blank, think I would prefer the latter as I have been know in the past to play with Tri SLi...are th correct products available on Daz site?
Okay, think I got what I would need, anyone can chime in really...to confirm...again, using top slot and 3rd Slot RIVE
Heres the GPU WB's I'm going to order:
2 x https://www.dazmode.com/store/produc...-acetalnickel/ (is it advantageous to go Acetol + Nickel vs just Acetol ? )
2 x Backplates:
https://www.dazmode.com/store/produc...ckplate-black/
Now, think I got this right, plaease confirm, for these Blocks arranged in top slot and 3rd Slot RIVE I'll need these "EK FC Terminal Triple Serial"
https://www.dazmode.com/store/produc...iple-parallel/
And this blank
https://www.dazmode.com/store/produc...lank-parallel/
Am I missing anything else with the GPU's ?? Do I need the Links connectors or is the whole idea of the Terminal being Links not required?
Also with these Acetol + Nickel Blocks what woould be the most appropriate material for Fittings (bearing in mind Galvanic Corrosion...yeah I work on a ship) ;)
Cheers n thanks in advance!!
B
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
  #615 (permalink)
Old April 11, 2014, 12:50 PM
Dazmode's Avatar
See in line.
Please e-mail store for the future inquiries.
>> NO ETA from EK.
>> OK. Everybody start from XSPC.
>> plenty
>>> When unsure best to use adjustable fitting: 1-2 slot or 2-3 slot.
>>>For the millions time - does not matter. But make sure you GPU is reference design. Use EK watercooling configurator.
2 x Backplates:
And this blank
>>> Refer to pictures in product description it shows what slots needs to be used and provide exact measurement in mm, so you can check.
>>> It is either terminal connector OR fittings.
>>> You better start watching my YT tutorials to get from level zero. Any fitting in the store OK.
B
  #616 (permalink)
Old April 12, 2014, 05:17 PM
rjbarker's Avatar
Yeah okay thanks...been through your youtube tutorials......biggest question I had was whether the Terminal Bridge I mentioned above will work on a RIVE or not (with top slot and and 3rd slot occupied) and what I need as far as "blanks"...being the "expert" on WC'ing and considering I'm about to pull the pin on closer to .9K on gear from your store thought you may know....no worries, getting some answers to the Terminal question on ROG's....the Terminal looks far better then a cheezy adjustable tube between the 2 Cards and considering I do go Tri SLi a 3 space Terminal for 2 Cards initially is what I'm looking at...hence the query on the right blank for the middle....thanks.
I have purchased from Frozen CPU in the past and I do see they have the backplates available, so I'll order them thru them ;)
RJ
Timespy: 18.613K
MARK 11: 40.185K
  #617 (permalink)
Old April 12, 2014, 06:12 PM
Dazmode's Avatar
I don't know every piece of hardware in existence, this is why I recommend to use provided measurements in bridge description against actual board (assuming you have it already). It will be either as you said triple + blank or Dual-3Slot depending on spacing.
  #618 (permalink)
Old April 12, 2014, 06:35 PM
rjbarker's Avatar
^^^^ Thanks...I'll figure out the RIVE PCI-e spacing on my own...no worries...now if I go the Triple Card Terminal advertised on your site, is this blank all I need to blank the middle slot on the terminal to run 2 Cards ?
So this
with this
and these..for my SLi Evga 780 Ti's
For my SLi Evga GTX 780Ti SC's.......going this route will enable me to remove the blank and add a 3rd Card in the future if I choose to do so.
As said, I'll figure out on my own through other sources if that Terminal is compatible with my RIVE Board
Timespy: 18.613K
MARK 11: 40.185K
  #619 (permalink)
Old April 12, 2014, 07:23 PM
Dazmode's Avatar
Blank is just a piece of metal to cover holes on Terminal part, so water wont be gushing out. Would you get third card later, you just remove it and attach EK block to the same spot.
And yes, new EK blocks and EK Terminal are screwed together, there is no other parts are needed. This terminal only work with EK non-CSQ blocks, like you selected.
Older CSQ blocks use different part.
Also as as go with Nickel plated block, it better to make sure you use liquid with corrosion inhibitor to protect plating that just microns thick. So no silver, PT nuke and other home made remedies. Ice dragon, EK, TFC or Koolance are good choice.
  #620 (permalink)
Old April 13, 2014, 09:49 AM
rjbarker's Avatar
^^^^ Thank you Sir ;)
Timespy: 18.613K
MARK 11: 40.185K
Merry Christmas to Dazmode and all! Lpfan4ever Off Topic 13 December 18, 2009 11:01 AM
Good News and Bad News. need some advice. arekieh Troubleshooting 7 November 23, 2008 10:24 AM
AMD: Want the good news or the bad news first? Cheator CPU's and Motherboards 7 July 20, 2008 08:03 PM
