  #31 (permalink)
Old April 28, 2010, 08:45 AM
Dazmode's Avatar
Indigo Extreme extreme overclocking LGA1156 kits are in. Just were released by Enerdyne.
Orange Build: Final Video
HTPC Build: Final Video
  #32 (permalink)
Old May 7, 2010, 03:26 PM
Dazmode's Avatar
Liquid FusionUV Pink! $45
helix is red under normal light.
  #33 (permalink)
Old May 7, 2010, 04:00 PM
Dazmode's Avatar
Ek will be re-leasing ASUS Rampage III block very shortly. Taking pre-order requests.
Those of you who asked already, do not need to ask again. :)
  #34 (permalink)
Old May 9, 2010, 09:31 PM
just a question for you daz. i would like to order all my WC bits from you but theres a couple of items you dont stock that im going to need. would you concider ordering in a few componets in for me, mainly an xspc dual bay dual ddc pump split res , 2x mcp 355's or laing ddc's, 480x480 mesh. ive got over a 1000 bucks to drop on wc gear and id prefer to spend it with you but if i have to make a seperate order to the states ill probly just get everything from frozen cpu or sidewinder or somthing. anyways let me know.
thanks
Danger Den / Laing DDC-12V Center Inlet 18 Watt Version 3.2 - FrozenCPU.com
XSPC Dual 5.25" Bay - DDC Dual Pump / Dual Split Reservoirs w/ Blue LED Light - Clear (DDCBAYTWO) - FrozenCPU.com
ModRight ModMesh 480mm x 480mm x 1.0mm HEX Aluminum Mesh Panel - Black - FrozenCPU.com
  #35 (permalink)
Old May 9, 2010, 09:40 PM
Dazmode's Avatar
Mmm, I will be ordering some stuff from Frozen soon, so I guess I can add this to order. Can you make shopping cart at Frozen site and PM me with its contents?
  #36 (permalink)
Old May 10, 2010, 07:19 PM
done. thanks alot daz
  #37 (permalink)
Old May 14, 2010, 10:38 AM
Dazmode's Avatar
LGA1366 Limited Edition Heatkillers are back!
  #38 (permalink)
Old May 14, 2010, 11:16 AM
Dazmode's Avatar
Koolance CPU-360 and GTX480 blocks back in stock too.
  #39 (permalink)
Old June 9, 2010, 10:39 AM
Dazmode's Avatar
Finally got Liquid Fusion 250ml reservoirs back... it was lo-o-ong wait.
  #40 (permalink)
Old June 10, 2010, 02:41 PM
Dazmode's Avatar
Huge load of EK re-fills arrived today after 2 weeks in customs struggle. Rampage III blocks are finally in...all flavors of HF and etc.
Merry Christmas to Dazmode and all! Lpfan4ever Off Topic 13 December 18, 2009 10:01 AM
Good News and Bad News. need some advice. arekieh Troubleshooting 7 November 23, 2008 09:24 AM
AMD: Want the good news or the bad news first? Cheator CPU's and Motherboards 7 July 20, 2008 08:03 PM
