  #181 (permalink)
Old January 4, 2011, 10:17 AM
CTA's Avatar
CTA CTA is offline
ah... i am missing to see at EK-FC6970 Full Cover Block for HD6970 - Acetal EK-FC6970 Full Cover Block for HD6970 - Acetal [EK-FC6970 A] - $109.99 : DazMode, Canadian PC Water Cooling and Modding Store
i was just looking at EK-FC6970 Full Cover Block for HD6970 - Acetal-Nickel EK-FC6970 Full Cover Block for HD6970 - Acetal-Nickel [EK-FC6970 A-N] - $119.99 : DazMode, Canadian PC Water Cooling and Modding Store
i might need two acetal hd6900... i will find out soon...
  #182 (permalink)
Old January 10, 2011, 02:55 PM
Dazmode's Avatar
Back from CES at 5 am today.... I have almost 3 hours of CES footage + interviews with DD, Ek, TFC, MagicCool, Corsair, Swiftech, Bitspower, FrozenQ, Xtreme party... . Exclusive interview for ADMIRALs with all details and actual product (can you belive that?) in my hands. Got almost arrested in airport at security point. Thing looked really bad on x-ray. Loads of you tube is coming.
P.S. Really happy back to Canada.
Orange Build: Final Video
HTPC Build: Final Video
  #183 (permalink)
Old January 10, 2011, 03:39 PM
Awesome, can't wait to see and hear your findings.
  #184 (permalink)
Old January 12, 2011, 02:32 PM
lowfat's Avatar
Do you ever plan on stocking any of Mayhems Dyes? They seem to have the best colour and consistency from what I have seen. Just no where in Canada to buy them.
Mayhems Dye - Mayhems Dye
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #185 (permalink)
Old January 12, 2011, 03:30 PM
Dazmode's Avatar
They promised to send me some sample, which have never show up. To be honest dyes are not on top of my priority list at the moment.
  #186 (permalink)
Old January 24, 2011, 02:56 PM
Any chance of primochill tubing? I'd really like to see some 7/16" ID Tubing for clamp less builds with 1/2" ID Barbs.
Also, HW-Labs radiators, specifically the GTX 120mm sized ones. Dazmode has all of those awesome high speed fans but no radiator to truly take advantage of their power!
  #187 (permalink)
Old January 24, 2011, 03:11 PM
Dazmode's Avatar
HW-Labs have never reply on any of our requests. We might go to the source and just get Magicool rads.
Primo is under discussion, but such odd sizes as 7/16 is big question as they sell ones in a blue moon. We can't sell 50x of 7/16 EK fitting for over the year, so I'm skeptical.
  #188 (permalink)
Old January 24, 2011, 03:33 PM
You don't use 7/16" ID Tube with 7/16" ID Fittings, you use it with 1/2" ID Fitting. Because the tubing is smaller than the barb it makes it very hard to push over, you don't even need hose clamps!
Here is a picture from one of my buddies over at OCN:
If you look at the GPU you will see that there are no clamps over the barbs (Some barbs have clamps, he put them on because he had them anyways) This is 100% safe, many, many people use it. It's also the perfect size of tubing to replace the Rasa kit's tubing as it's the exact same size and will work nicely with the included 1/2 barbs.
  #189 (permalink)
Old January 24, 2011, 03:38 PM
Dazmode's Avatar
LOL, ok sold. I will make a note to look into that.
  #190 (permalink)
Old January 24, 2011, 06:45 PM
Yeah if you do get it put a note in the rasa kit description saying "For colored tubing look here" then link to the page of 7/16" tubing. Perfect.
I will be buying some of this soon when I get the Rasa kit for my friend. (In about 3 months)
Merry Christmas to Dazmode and all! Lpfan4ever Off Topic 13 December 18, 2009 11:01 AM
Good News and Bad News. need some advice. arekieh Troubleshooting 7 November 23, 2008 10:24 AM
AMD: Want the good news or the bad news first? Cheator CPU's and Motherboards 7 July 20, 2008 08:03 PM
