Old February 6, 2010, 01:01 PM
HumorusPrawn's Avatar
Default Radiator Question
I was wondering if there is a designated in and out port on radiators, my thermochill PA120.3 doesn't say anything. Does it matter? Please tell me if it matters or not, and if it does tell me which side. A or B
Old February 6, 2010, 01:06 PM
3.0charlie's Avatar
No difference for the 120.2. Either port works fine.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old February 6, 2010, 01:08 PM
Okay, sweet this means my setup will look a lot cleaner, lol. Thanks!
Old February 7, 2010, 12:33 AM
Liu Kang's Avatar
As mentioned, it doesn't matter... however, I'd be careful on how you setup the rad, and which you use as inlet/oulet. Always try to setup your rads so you can drain your system easily.
G'luck.
LK
TINY KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | Corsair HX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x ST1000F | 4x 160GB SSD | 15x 120mm rads | Under construction...
Old February 7, 2010, 02:30 AM
Jackquelegs's Avatar
The only times you would have to worry is when the radiator uses Front-back dual pass design (like the HWlabs GTX360). Not the case with the PA series as they use Side-side dual pass
Iapetos
Zephyranthes
[WTT] radiator and a pump anabioz Buy/Sell & Trade 5 October 28, 2009 05:33 PM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 03:44 PM
Question about Danger Den radiator barb fittings AERo Water Cooling 16 March 31, 2009 12:23 PM
Radiator Question Scart Water Cooling 22 March 12, 2008 02:49 AM
Radiator? nick_black Water Cooling 8 February 12, 2008 08:24 PM
