Old February 1, 2010, 08:59 PM
AmuseMe's Avatar
Default Fan Controller for Radiator Fans
I am just bumping this old post back up as I have not yet found a solution... Also, the plans changed from my original plan (seen below).
NCIX emailed me today saying that the Lamptron FC5 that I ordered over a month ago is still not in stock, and they have NO ETA on more. They asked me if I would like to switch it for something else. I heard that the previous FC series made squeeling sounds with the fans, so I am a little turned off about that.
I dont mind the knob idea, but if there is an LCD display, or LEDs, they must be either white or red. I really do not want to do any modding wither I was going to get a BigNG, but there are no Canadian online stores that sell them, nor do any sell the Aquaero controller.
Now I am needing a fan controller.
What It Needs
- Any lighting (LEDs, LCD) must be red or white.
- Must have a MINIMUM of 20W per channel.
- Thats about it
Update: Daz... That Akasa controller you have is calling my name. How does it perform?
I only deemed that this should go in the "Water Cooling" section because it is for the fans specifically on the radiator(s).
I am looking for a fan controller, preferibally one that has no knobs, switches, etc. etc. that would interfere with my TJ07's (future) face plate. I would prefer an internal one, or one that can be hidden like the T-Balancer T-Balancer® bigNG MultiFunction Fan / Pump Controller or the Aquaero Aquaero 4.00 USB Fan-Controller, VF-Display.
I am needing a controller that could power atleast three fans (@2.16W) on one channel/ controll.
Any ideas out there?
Old February 1, 2010, 09:11 PM
ZZLEE's Avatar
Default 5.5 Bay control
PC Cyber Canada - For All Your Computer Needs 5 fans contolled FrozenCPU.com | 1.877.243.8266 | World's Largest Selection of PC Modification Supplies
Or look at frozen but shipping and custums
look there or maybe DAZOMED site
Old February 2, 2010, 06:38 AM
Post Opinion
If you can sacrifice 2 drive bays and you are patient enough to carefully probe and wire this thing it is a very good option.
NZXT Sentry LX - Aluminum Dual Bay Fan Controller - Black Products Model: SENTRY-LX [SENTRY-LX] : Performance-PCs.com, ... sleeve it and they will come
Old February 2, 2010, 02:33 PM
Dazmode's Avatar
My LX annoys me, I much happier with Sunbeam Rhoebus Extreme on my other machine (although it doesn't show RPMs)
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old February 2, 2010, 03:01 PM
AmuseMe's Avatar
It only support 4W per channel - meaning, two of my fans would be too much draw for it. I am looking for atleast 10W+ per channel. The Rheobus extreme did 30W, but I sold mine because I do not like the "knobs"
Old February 2, 2010, 03:30 PM
BigDogg's Avatar
You can look at the Lamptron series, although they produced a terrible high pitched whine with my Scythe fans so I had to RMA the unit. I am thinking about going back to the Sunbeam as it did not produce any whine with the exact same fans. Personally the Lamptron looks the best but the Sunbeam to me is the best of the bunch in terms of components and functionality. As for the knobs.. I don't really like them either, I might check Sayal to see if they have any replacement knobs that would fit..
Old February 2, 2010, 04:28 PM
Dazmode's Avatar
I'd like to get some of those: Akasa Thermal Solution
Old February 2, 2010, 06:53 PM
What's wrong with the LX? I was thinking of getting one, they look sexy...
Of course, the 4W per channel would not allow me to run two of those 1900 RPM S-FLEX AmuseMe sold me at full speed (they use about 2.8W each), but they'd run around 1350 RPM, and with 6 of them, I'm guessing it would be enough. I just love the Star Trek look of the Sentry LX.
Old May 5, 2010, 11:04 PM
AmuseMe's Avatar
Updated the question, and didnt want to post a new thread with the exact same topic... bump
Old May 6, 2010, 05:21 AM
gingerbee's Avatar
really not sure if this helps can't find specs for wattage per channel Newegg.ca - Sunbeam MFPP Multi-Fan Power Port - Adapters & Gender Changers
Fan Hole & Radiator Template Downloads Mnpctech Guides & How-to's 6 October 30, 2009 04:07 AM
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 10:32 PM
Fan controller question + fans ADay2Long Air Cooling 1 May 21, 2009 05:20 PM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 03:44 PM
fan controller help Computergeek Troubleshooting 19 July 25, 2008 03:28 PM
