Old May 6, 2010, 08:28 AM
MpG's Avatar
MpG MpG is offline
Originally Posted by gingerbee View Post
really not sure if this helps can't find specs for wattage per channel Newegg.ca - Sunbeam MFPP Multi-Fan Power Port - Adapters & Gender Changers
That's not a controller - it's just a splitter/adaptor, so it won't actually be dissipating any heat itself, which what creates the wattage limits on fan controller. Baring some amazingly poor internals, it's limit would be pretty much the same as regular plugs and cabling.
Old May 6, 2010, 09:29 AM
AmuseMe's Avatar
I might have to just wait it out on that FC5
Old May 15, 2010, 02:48 PM
AmuseMe's Avatar
Does anyone know the difference between the LCD screens of the FC6 and FC5? Lamptron said the FC6 has a better screen...
Old May 17, 2010, 07:10 AM
AmuseMe's Avatar
Anyone?
Fan Hole & Radiator Template Downloads Mnpctech Guides & How-to's 6 October 30, 2009 03:07 AM
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
Fan controller question + fans ADay2Long Air Cooling 1 May 21, 2009 04:20 PM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 02:44 PM
fan controller help Computergeek Troubleshooting 19 July 25, 2008 02:28 PM
