  #51 (permalink)
Old October 23, 2007, 07:59 AM
Get an aftermarket top for the 355, like the Alphacool.
Those allow you to use any barbs, and because of the option to put the inlet at the top over the impeller, (stock top does a 90-degree turn onto the impeller) and make the pump quieter too (Delrin tops however, seem to make the pump louder).
  #52 (permalink)
Old October 23, 2007, 11:03 AM
Apollo4g's Avatar
Yup i thought of that, but if he puts an after market to the barbs wont be on one side of the pump anymore.
One will be on top and one at the side. There for he might as well get a 655 pump.
If you go that way go with the petra's top.
http://www.ncix.com/products/index.p...=Petra%27sTech
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
  #53 (permalink)
Old October 23, 2007, 12:13 PM
Shadowmeph's Avatar
ok I am actually starting to wonder which pump is better because the MCP355™ 12 VDC Pump has 20' of head ( high lighted in bold)
* Small Footprint: 2.4" x 2.4" x 1.5"
* 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime.
* Superior 12 Volts DC convenience: plugs into the computer power supply
* The MCP355™ can be used with full confidence in any MP servers, and high-end workstations.
* Superior real world performance thanks to its high pressure characteristics (20ft of head). The MCP355™ is particularly well adapted to the proliferation of daisy-chained liquid cooling devices in a single circuit: Multiple Processors, Chipset, Graphics, and Hard Drives.
* 3/8" barb fittings.
* No maintenance when used with de-mineralized water, and anti-fungal additives (Our HydrX™ additive is recommended)
* Quick installation with adhesive neoprene pad, or permanent installation with screws and grommets.
* RPM sensor plugs to 3 pin motherboard fan connectors and reports impeller rotational speed
And The MCP655™ pump has only 10" head ( high lighted in bold) this confuses me because I thought that the 655 pump was better but then I read that the higher the head the better the pump. so what gives lol
Nominal voltage 12 V DC
Operating voltage range 8 to 24 VDC
Nominal power (@ 12 V)24 W
Nominal current (@ 12 V) 2 amps
Motor type Brushless, microprocessor controlled
Maximum head 10 ft (3.1 m)
Maximum discharge ~ 317 GPH (1200 LPH)
Connection size " barbs
Maximum pressure 50 PSI (3.5 BAR)
Temperature range 32 F to 140F (0 C to 60 C)
Electrical connector Molex 4 pin
Weight 1.4 LB (650 gr.)
  #54 (permalink)
Old October 23, 2007, 12:50 PM
Misoprostol
Guest
Posts: n/a
The MCP355 is at LEAST equal to the MCP655 in real work performance without a custom top. If you put a custom top on it, then it's better.
  #55 (permalink)
Old October 23, 2007, 12:53 PM
sswilson's Avatar
I'm not an expert by any means, but if I had to guess I'd say the difference in head pressure was due to the ID of the tubing they support. That extra 1/8 ID adds a substantial amount of water in the loop to be pushing around.
Really???? And in such a small package???
Wish I had done a bit more research before picking up the 665 then...... (I wanted 1/2" though so that's ok... :) ).
  #56 (permalink)
Old October 23, 2007, 06:19 PM
The Alphacool top has another inlet where the stock one would be, so he can keep the small form factor of the pump (and the inlet and outlet both being on the side), while having a quiet(er) pump.
Alternatively, he can reduce the noise by a fair bit if he loosens up the screws on the bottom of the pump by about 1/16~1/8 of a turn
Thinking About Watercooling - Where To Buy? ChuckleBrother Water Cooling 17 March 24, 2008 09:30 PM
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Help With Watercooling! Gasp! llama_egg Water Cooling 27 December 8, 2007 10:06 AM
Gigabyte watercooling kit Vinnie Water Cooling 1 November 27, 2007 08:18 PM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
