Old October 8, 2007, 12:47 PM
cdn_Madrach's Avatar
Originally Posted by Babrbarossa View Post
I think you could fit the pump and res in the empty drive bay fairly easily. Have you considered the top of the case for rad mount- some people do rear mounts by letting the top of the rad extend above the top of the case a little so that it doesn't block essentials (cdnmadrach)
My rad blocked the back of my case a little but when I added a second set of spacers on the rad box there was plenty of room:) (finally got that one sorted out Babrbarossa)
PS: I was worried about how sturdy the radbox would be and it actually is very sturdy.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old October 8, 2007, 12:57 PM
There are always solutions when water-cooling. Changing the case is one. If you wish to keep your 900, then you could mount the rad backside, just like I did for a customer on his P180.
Plenty of space for the cables, since Swiftech provides a radbox between the case and the fan. Also to answer your question, the pump MUST be lower than the reservoir.
John
is that a piece together or is that a kit that you purchased?? Lookes like the one I mentioned above...no? thankyou for posting the photo, it always helps to see the stuff for real!!
as for the Stacker case, this is at another fourm and this is what he did....but I can't see me buying another case now..... mommas gonna flip when or if this stuff shows up at the door!! LOL....
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old October 8, 2007, 05:28 PM
3.0charlie's Avatar
Actually, the rad, fan (x2) and the Radbox all come from the Swiftech water-cooling kit. Nice little add-on.
Hydro-Quebec is salivating...
Old October 9, 2007, 02:51 PM
when you guys refer to a second loop for the GPU's... u mean a hole separate pump and such and rad, or just a split in the line so theres 1 in, then splits and coolant goes to the cpu and GPU separatly, then the line meets up again and enters the rad as 1...
IS THIS A 2 LOOP SYSTEM?? pardon teh rough draft, but I think you will get the picture....
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old October 9, 2007, 03:36 PM
Cptn Vortex's Avatar
I think what they mean by a loop is having one Rad cool the CPU, and another RAD for cooling the Videocard/Chipset
So like this - RES - Pump - Chipset - VGA - RAD - CPU- RAD - RES.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old October 9, 2007, 04:21 PM
Babrbarossa's Avatar
Yeah, what captain vortex said would do it- some purists might say you need two completely separate loops- each with its own pump to maitain high flow rates, but I'm not sure how necessary it is.
I like the stacker pic- I have one coming in a week and I'm going to set it up with a watercooled quad core- I'm wondering how they get at the back panel with that setup though...
Old October 9, 2007, 04:29 PM
I hope you guys will like my Apex Ultra+ job in my TJ09. I'll get pics up tonight! I think it looks stellar! (I hope temps are good)
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old October 9, 2007, 04:53 PM
BALISTX's Avatar
That stacker looks sweet. That rad looks at home on the back of that case.
Heatware
HWBOT
  #19 (permalink)
Old October 9, 2007, 06:58 PM
sswilson's Avatar
I'm not sure how many folks run a split loop like the one in your pic.
I'd be afraid to as I'm assuming that the water would take the path of least resistance, so unless the components in each branch have the same resistance to flow I'd think that one side of the split would get the great majority of cooling water flow.
  #20 (permalink)
Old October 9, 2007, 07:32 PM
Supergrover's Avatar
Thats one fine stacker!
R.I.P.
Thinking About Watercooling - Where To Buy? ChuckleBrother Water Cooling 17 March 24, 2008 09:30 PM
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Help With Watercooling! Gasp! llama_egg Water Cooling 27 December 8, 2007 10:06 AM
Gigabyte watercooling kit Vinnie Water Cooling 1 November 27, 2007 08:18 PM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
