<~----> HeatKiller 3.0 Mounting? - Page 2 - Hardware Canucks
Old October 11, 2010, 05:43 PM
ottoyu34's Avatar
you measure from the top of the mounting plate to the top of the screw.
ruler or calipers would work.
ATCS 840| Core i7 920 - 4.2Ghz - H20| Corsair Dominator GT 1600Mhz 6GB| EVGA X58 Classified| GTX480 2-Way SLI| WD 640GB X2 (Raid 0)| Corsair HX1000W
Old October 11, 2010, 07:45 PM
JD JD is offline
Originally Posted by chriskwarren View Post
The '200N' pressure instruction; seems that you can use calipers to measure the distance to get proper pressure (19.6mm). Did you use calipers or just tightened by hand and judged that way? If you measured, where exactly did you measure it from?
I did all that measuring BS the first time around, and it was fine. Second time I didn't and just put it until it was all nice and snug (using the provided allen key). Temperatures are still the same, so whatever. No harm done.
Old October 11, 2010, 09:21 PM
KaptCrunch's Avatar
i didn't use the red or nylon washers to mount my HK3 no flexing MB for studs floated through holes in MB
oh the 200n referrs to 200 newtons = Pounds-Force 45lbs on WB surface
[FS] Thermochill, Heatkiller, UN, Koolance, Bitspower mhw100 Buy/Sell & Trade 13 February 28, 2010 07:25 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 03:21 AM
Heatkiller D5 Pump Top Technokat Water Cooling 7 January 18, 2010 06:07 PM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 07:12 PM
Today, I've become a believer with Heatkiller rev 3.0 ontariotl Water Cooling 40 September 8, 2009 06:32 AM
