Old January 24, 2010, 12:47 PM
chrisk's Avatar
Folding Captain
Default Swiftech MCR220 with integrated pump any good?
Hey guys;
Thinking of something like this to add to my main desktop:
Swiftech MCR220-DRIVE 2 x 120mm Radiator w/ Integrated Pump Housing ( WITH PUMP) Products Model: MCR220-DRIVE [MCR220-DRIVE] : Performance-PCs.com, ... sleeve it and they will come
I have some questions:
1. Is this any good? Anyone have an experience with this product?
2. Would it need a res? I would mount vertically at the back of the case.
3. I currently have two GTX 285s and an i7 920 (D0) on one loop. If I picked up this product (or went with another loop and a double rad), would this rad do a decent job on the cpu, or should I put the GPUs on it? At full load folding, my i7 does low 70s, with occasional spikes to mid 70s (3.6GHZ). The GPUs are now hitting high 50s, low 60s max.
4. I would use the rad box to mount on the back of the case as shown here:
Anyone anticipate problems mounting the rad to the 120mm section of the rad in the other mounting area? (right above the hoses)
Thanks on any advice!
Chris
Fold for team #54196
Old January 24, 2010, 01:01 PM
3.0charlie's Avatar
should be fine since it uses a MCP-355. Integrated res, no need for another one. It will be fine for the CPU for sure. But take a look at the price, that's what convinced me to build a loop from used parts...
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old January 24, 2010, 01:48 PM
What blocks are you using right now?
I swapped my FuZions to Apogee XTs and my temps dropped about 10C - mostly because of the increased mounting pressure.
heatware
Old January 24, 2010, 02:56 PM
chrisk's Avatar
Folding Captain
That loop uses Alphacool Niagara.
Old January 24, 2010, 03:37 PM
I would wait a bit before jumping on these. Swiftech had alot of issues with their last all in one attempt. I would like to see how long these stand up.
heatware
ebay
Old January 25, 2010, 12:22 PM
Dazmode's Avatar
I wonder if pump will resonate with rad making it a noisy combination...
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old February 4, 2010, 10:09 PM
Wow this seems like a very good idea ! good pump also
Old February 4, 2010, 11:34 PM
HumorusPrawn's Avatar
Why are there fan grills on that side of the rad...LOL
Old February 5, 2010, 12:19 AM
sswilson's Avatar
Heh... good eye!!!
I never would have noticed as it's been a long time since I've had a rad in this household that didn't have push/pull.....
Purely looks I guess.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old February 5, 2010, 12:25 AM
Jackquelegs's Avatar
I'm quite concerned over the inlet hole size on that rad pump combination. From the specifications I've seen it's rather small, and I'm not sure how big of an impact it will make...
Overall this is a great idea, and should be definitely a choice for someone that wants an all-in-one WC system.
Here are the mounting options
3. I wouldn't put all that on a MCR220. You should make a separate GPU loop
4. Mounting shouldn't be too much of a problem. Sometimes though, the rad does block some DVI-ports
Iapetos
Zephyranthes
[WTB] swiftech 350/355 pump + top, ramsinks upsidedown Buy/Sell & Trade 2 June 12, 2009 06:12 PM
Mcr220-qp-stack Shadowmeph Press Releases & Tech News 10 April 9, 2009 09:05 AM
[WTB] Swiftech MCP655 pump, Dtek Fusion 2, Noctua p12 netforce Buy/Sell & Trade 3 January 13, 2009 07:16 PM
Integrated Video Mobo's SugarJ CPU's and Motherboards 22 September 2, 2008 08:31 PM
Swiftech H20-220C + Coolermaster CM690 = Pump Noise! Arrgh! Nate_The_Great Troubleshooting 2 January 22, 2008 01:58 PM
