Old January 23, 2010, 04:23 PM
JD JD is offline
Default HWLabs SR1-360 vs Feser
I can't really decide between the SR1 and Feser 360 radiators. I assume either will suffice for my i7 920 @ 4.2/4.4GHz along with a "next-gen" graphics card. Whatever ATI's next card may be, or the Fermi/GF100. However I'm curious if either will perform noticeably better.
I doubt my MCR220 will cut it, which is why I'm looking to upgrade.
I'll be pairing it up with Gentle Typhoons @ 1450RPM.
Old January 23, 2010, 04:58 PM
Dazmode's Avatar
You might want faster fans for what you're trying to it use for...
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old January 23, 2010, 05:51 PM
JD JD is offline
I hate noise though...and ~1500RPM is already fairly audible.
And don't those Gentle Typhoons have pretty good pressure? At least that's what I've read on XS.
Old January 23, 2010, 06:22 PM
aCid888*'s Avatar
I own the Feser and it is one of the best 360's around and I do believe its a little better than the SR1.
To put it another way; I would buy it again if I was to buy new.....you need some decent fans though as the fins are pretty tightly packed.
Hers (pInky):
945ES @ 3.92GHz (1.5v) - Lapped Fuzion v1
MCP-355/XSPC Top + Black Ice Extreme 360
Asus M3A79-T Deluxe 790FX (MX-2 NB + SB)
2x2GB G.Skill Pi Black @ 900MHz 444-12
PNY "XLR8" 9800GX2 @ 704/2202/1760
Seagate 500GB + XP SP3
22" Acer P223w @ 1680x1050
Modded Lian Li PC-60F
SB Audigy 2 w/ Heatsink
Old January 23, 2010, 06:31 PM
Dazmode's Avatar
Then consider 38mm or larger fans. The i7 runs quite hot. I have no problem with my HAF set up with 6 water blocks in the loop (see sig) @ 1300 rpm x6 fans , but I don't overclock. MCR220 could not handle even single i7 for me and was removed swiftly.
Old January 23, 2010, 06:47 PM
aCid888*'s Avatar
Delta's & Pana's are expensive......these may be perfect for you.
Scythe Ultra Kaze 120MM High Static Pressure Silent Fan 38MM 2000RPM 87.6CFM 32.9DBA - DirectCanada
Me, on the other hand...would much prefer these:
Scythe Ultra Kaze 120MM High Static Pressure Fan 38MM 3000RPM 133.6CFM 45.9DBA - DirectCanada
Hers (pInky):
Old January 23, 2010, 07:40 PM
JD JD is offline
Well the SR1 seems geared for low-speed fans, so I'm guessing that's more in line with what I want. My other choice was the XSPC RX360, but those seem a little harder to get. Least the SR1/Feser can be had in Canada.
And I'll agree, my MCR220 isn't holding up too well with my i7 920 right now. Gets close to 80C at times. I'm hoping a dual-pass 360 radiator will suffice with a GPU added as well. I'm not looking for the best temperatures, just within a decent range.
I still have a ton of voltage tweaking to do with my i7 anyhow. Trying for 4.2GHz now (210x20) without Turbo but with HT.
As for 38mm fans, there aren't really any quiet ones. I know there's 1000RPM Ultra Kazes, but those apparently make a ticking noise or something.
Old January 23, 2010, 07:45 PM
Dazmode's Avatar
I have 3000rpm San Aces that slowed down to 1500 rpm and they are pretty good at noise level. Triebwerk pretty good too, but I couldn't fit them.
Old January 23, 2010, 08:42 PM
JD JD is offline
Triebwerks are too damn expensive. I know I own some Noctua's which were like $15 a fan, but ~$30 a fan is a bit insane.
And I know San Aces are good, but aren't they rather hard to find?
Old January 23, 2010, 09:02 PM
Dazmode's Avatar
Yes, getting San Aces is pain.. waiting time 120 days...
Spilled Feser One Coolant AmuseMe Water Cooling 10 November 9, 2009 09:18 PM
[FS] FS: Feser X-360, 17mm spacing bernZ Buy/Sell & Trade 4 November 6, 2009 09:08 PM
Q&A on Feser Liquids Dazmode Water Cooling 7 June 10, 2009 03:51 PM
The Feser Fairy Frank Booth Water Cooling 17 April 23, 2009 08:42 PM
[EXPIRED] Hot! Feser One X-360 for only $99.99 @ NCIX S_G Computer & Electronics Hot Deals 15 January 27, 2009 05:03 PM
