<~----> Radiator Flushing Necessary? - Hardware Canucks
Old January 19, 2010, 10:19 PM
HumorusPrawn's Avatar
Default Radiator Flushing Necessary?
Do I need to do this?
If so what does it do to my rad?
I have the Thermochill PA120.3 it says its factory flushed but they recommend you to flush it.
Is this really necessary?
Old January 19, 2010, 10:28 PM
Absolutely.
Just get some nice hot boiling water and fill it up.. swish it around.. drain and repeat.
Old January 19, 2010, 10:39 PM
Originally Posted by enaberif View Post
Absolutely.
So I dont add anything to the water? just boil it?
and how will I know when to stop, will the water be murky at first and then get clear, or do I just swish it around a couple times?. Also what does this do?
Sorry watercooling NOOB here, just want to get everything right :D
Old January 19, 2010, 10:45 PM
Just water is fine.
And yes you'll see the crap coming out.
Old January 19, 2010, 10:54 PM
Just water is fine.
thanks, for the fast responses. When my rad gets back from RMA this will be the first thing I do!
Old January 20, 2010, 03:09 PM
Am I the only one to see a Radiator go on RMA.. I thought water cooling parts once used cannot be exchanged.
Anyhow, to the topic: Yes, but it must be boiling water, just keep repeating till you think that the rad is only pouring out clean water and no dirt.
Old January 20, 2010, 03:38 PM
SugarJ's Avatar
Wear gloves. The rad will get really hot if you use boiling water. I usually just turn my tap to max hot and let it flush through for 5 minutes.
Old January 20, 2010, 10:01 PM
It had a leak in the fins, manufacturer defect. Took it to NCIX, pretty sure they tested it and they gave me replacement papers. Just waiting for it to come in now.
Old January 21, 2010, 11:20 AM
Dazmode's Avatar
+1 May be 10 min...
Orange Build: Final Video
HTPC Build: Final Video
Old January 24, 2010, 12:59 PM
AmuseMe's Avatar
I boil distilled water and swish it. Then poor it through a coffee filter. When there is no visible particles I usually do it two-three more times
DEAD CA$H
Painting a radiator netforce Cases 9 May 1, 2009 06:31 AM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 02:44 PM
Which radiator? (issues) Micmal Water Cooling 2 June 19, 2008 12:23 AM
Gasket for Radiator? Dashock Water Cooling 4 May 17, 2008 03:27 AM
Radiator? nick_black Water Cooling 8 February 12, 2008 07:24 PM
