Old January 18, 2010, 08:06 PM
mattlef's Avatar
Default little help....
Hey guys,
for this little mod i have planned, i'm in need of some 1/4in tubing and 1/4in barbs, or some compression fittings that would work with some 1/4in tubing....
For the life of me, I can seem to find any..... any advice or ideas?
My Rig:
2500K - EVGA GTX580
Silverstone Fortress Mod
Ice-Dragon Mod
Upcoming Changes/Upgrades:
Old January 18, 2010, 08:09 PM
Fudd Rucker's Avatar
Check out a fish supply store, canadian tire or home depot. One of them should be able to help you out, as for the compression fittings you might have to order those from the states or UK
Swiftech MCP-655 | EK Supreme Acryllic
XSPC 360 | DD Dual 5.25"
Primochill 1/2" Tubing | 3 x 38mm Kaze 3000rpm
EK Nickel GTX 480
Old January 18, 2010, 08:10 PM
MarkOne's Avatar
I have some thermaltake stuf with 1/4 tubing. barb, rad, cpu block, fittings, name it
Old January 18, 2010, 08:23 PM
mattlef's Avatar
Correct me if i'm wrong, but 8mm ID - 10mm OD is 1/4 in tubing right? or would that be 3/8.... if its 3/8ths then I can get pretty much everything from here and ncix.
My Rig:
2500K - EVGA GTX580
Ice-Dragon Mod
Old January 18, 2010, 08:32 PM
MarkOne's Avatar
8mm will be near 5/16
and 10mm is near 3/8
Old January 18, 2010, 08:36 PM
mattlef's Avatar
hmm, Thanks Mark.
In that case, i'm pretty restricted with what i can do for this little mod i have planned.....
I might as well just go all out.
My Rig:
2500K - EVGA GTX580
Ice-Dragon Mod
