Old October 4, 2007, 04:51 PM
3.0charlie's Avatar
Question Air cooling for E6400
Quick question regarding air cooling: I have the E6400 running @ 3.36, with 54C loaded using F@H. I know I can push even more, in the 3.6-3.7 range - the limiting factor being the Arctic Freezer 7 sitting on top of it. At those speeds and temps, it's out of its league.
I've selected 2 HSFs, one being in special with the Sponsor sale @ NCIx, the Tuniq 120:
http://www.ncix.com/products/index.p...7&promoid=1056
and this one I found @ DC:
Thermalright ULTRA-120 Extreme 6 Heatpipe Cooler LGA775 Heatsink *Fan Not Included* - DirectCanada
The Ultra-120 will using the Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM.
Which one should I choose?
John
Old October 4, 2007, 04:58 PM
Whichever you can afford.
The Ultra pulls ahead by a few degrees but nothing major and it also comes down to size.
The Tuniq is MASSIVE and the Ultra is big but not near as big as the Tuniq.
I have the Tuniq on my e6600 and its running at 3.4ghz @ 1.4v and it idles around 45 degrees
Old October 4, 2007, 05:05 PM
3.0charlie's Avatar
Price is not an issue - I've quit smoking and I'm buying myself a gift.
Size is also not an issue, since it will be installed on HSPC test bench.
I'm checking out the IFX-14 with its backplate cooler (Ultimate CPU Cooling Solutions! USA) and I'm wondering if it would be a good buy since there is hardly no space between the bench surface and the board.
Old October 4, 2007, 05:07 PM
I've done a few subjective readings on the IFX-14 and it doesn't perform as well as the Ultra 120 and if its going to be on a test bench you might want to look at something like the Ultra 90 which is smaller than the 120 but works as well or go for something like the Zalman 9700.
Old October 4, 2007, 05:42 PM
Cptn Vortex's Avatar
The Ultra 120 Xtreme is really an amazing cooler, and definitely worth the price premium. I have it, and also have a Scythe ninja, and the build quality between the two is immense. The Thermaltake is so solid, so perfect. They obviously take care in the design and build. Plus, there is a massive amount of heatpipes there. It is really an amazing sight.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old October 4, 2007, 05:46 PM
3.0charlie's Avatar
Capt, what are the load temps on that X3210 using the Ultra120?
Old October 4, 2007, 06:08 PM
Right now I get load temps of about 68-72 when ambient is in the mid 20's. I use a Antec Tricool 120mm fan on medium on the Cooler, cause they Yates won't mount. Keep in mind I lapped my CPU, whick did drop my temps about 2-3 degrees.
The only thing I can really compare this cooler too is the stock cooler, which, @2.67GHZ, UNDERVOLTED to 1.2V, was hitting 78-80 on load.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old October 4, 2007, 06:36 PM
3.0charlie's Avatar
Thanks for the info. I went with the IFX-14 for 2 reasons: 3 fans (Scythe Sflex SFF21E, for a quiet set-up) and the backplate cooler as part of the package. I'm concerned with the heat build-up since the board is resting straight on the top section of the HSPC bench test (though I did add a couple of .098" rubber washers to allow some airflow).
We'll see how it compares with the AF7Pro.
John
C2D E6400@ 3.2Ghz Needs Advice Please?! bushwickbill Overclocking, Tweaking and Benchmarking 8 January 18, 2008 10:18 AM
Comment thread for "Core 2 Duo e4300 vs. e6400: Performance on Air and Water Cooling Babrbarossa CPU's and Motherboards 12 August 7, 2007 08:12 AM
Need some help , stuck at 2.77 on e6400 bushwickbill Overclocking, Tweaking and Benchmarking 6 July 22, 2007 06:55 PM
e6400 @ 6.84GHz LOL!! Babrbarossa Overclocking, Tweaking and Benchmarking 11 April 28, 2007 10:39 AM
