Old January 17, 2010, 01:13 PM
Default Home made i7 water block
Just recently upgraded to an i7 so I thought why not try to make a block for it ...here are some pics and temps after first oc attempt...Im using a pa140.3 with 3 noctua 140mm fans ....all parts were machined by hand using power tools and jigs
would appreciate if you could share your temps of your w/c i7s at different speeds and voltages for comparison
Old January 17, 2010, 01:18 PM
3.0charlie's Avatar
Whoa. Nice. Very nice. Can you enable HT, and reload?
I have a 920 C0 at 3.9, HT enabled with a lapped D-Tek V1 / PA120.3 combo with triple YLs. Temps under load are 60C.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old January 17, 2010, 01:20 PM
Sushi Warrior's Avatar
Define hand tools and jigs... like a drill press? Or a manual milling machine?
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old January 17, 2010, 01:26 PM
Jack Rabbit's Avatar
Wow. You don't see a lot of people DIYing waterblocks anymore.
- James Graham
Old January 17, 2010, 01:38 PM
SugarJ's Avatar
Ahh, no HT. Although you might have a really good chip too. I'm still dialing in my D0, currently at 20x185 with the gear in my sig. Load temps are low 50's.
Old January 17, 2010, 02:00 PM
no milling machine was used ... drill press for the mounting holes, router with a 1/4" spiral bit for the block
Old January 17, 2010, 02:40 PM
aCid888*'s Avatar
Looks a bit restrictive...any chance of some more shots of the block???
Also, what pump do you use??
Other than that...great job and it looks pretty sweet with those green LED's.
Hers (pInky):
945ES @ 3.92GHz (1.5v) - Lapped Fuzion v1
MCP-355/XSPC Top + Black Ice Extreme 360
Asus M3A79-T Deluxe 790FX (MX-2 NB + SB)
2x2GB G.Skill Pi Black @ 900MHz 444-12
PNY "XLR8" 9800GX2 @ 704/2202/1760
Seagate 500GB + XP SP3
22" Acer P223w @ 1680x1050
Modded Lian Li PC-60F
SB Audigy 2 w/ Heatsink
Old January 17, 2010, 06:41 PM
1.33vcore for 4.2 ghz no ht...will try later with ht on
Old January 17, 2010, 06:54 PM
Perineum's Avatar
Even if it doesn't do as good as a commercial block, that's pretty damn awesome! Good work!
Old January 17, 2010, 07:49 PM
Jackquelegs's Avatar
Whoa hoho. That's radical. Wait, are you using 2 tubing sizes?
Iapetos
Zephyranthes
home made gpu water block Lazypixel Water Cooling 24 July 11, 2009 08:50 PM
Best Water Block for i7 Bubbzilla Water Cooling 7 July 8, 2009 12:54 AM
[WTB] CPU Water Block Lpfan4ever Buy/Sell & Trade 10 March 4, 2009 07:00 AM
[FS] 4870x2 with water block brewer265@ Buy/Sell & Trade 20 January 12, 2009 05:51 AM
EK Water Block miggs78 Water Cooling 20 October 12, 2008 07:13 PM
