  #21 (permalink)
Old February 10, 2010, 09:00 AM
respect
heat
rfd
hofo
  #22 (permalink)
Old February 10, 2010, 10:02 PM
biff's Avatar
Originally Posted by Lazypixel View Post
no milling machine was used ... drill press for the mounting holes, router with a 1/4" spiral bit for the block
Nice! Been a long time since I've seen a DIY block that didn't look like a hack job!
You say you used a 1/4" upspiral on the block... on copper? I've used a router on Al but not Cu. You got guts, I'd be afraid of it grabbing as all the copper work I've done I've found it very 'sticky' to machine. I'd like to hear more about the machining/jigging. Pics would be nice too!!!
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
  #23 (permalink)
Old February 10, 2010, 10:07 PM
That looks seriously nice.
  #24 (permalink)
Old February 15, 2010, 12:08 PM
Ive been meaning to post this pic for a while now.
The jig is made of 1/2" mdf and so is the circular offset guide (right bottom corner) that gets attached to the router base
Biff you are right about copper being 'sticky' while machined. To prevent that I used a compound that makes things run a little smoother. As far as grabbing goes you just remove one mm at a time to prevent that.
  #25 (permalink)
Old February 15, 2010, 01:51 PM
biff's Avatar
OMFG Man!! Genious. That opens up a lot of possibilities for me since you can do stuff with this you could only do with a CNC mill like that o-ring recess... unless you're were an etch-a-sketch guru and do that manually with the X & Y dials. BTW what did you use for that a 1/8" core bit? or just straight?
Even with removable templates. Just sweet! Thanks for sharing.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
  #26 (permalink)
Old March 8, 2010, 06:54 PM
Just a little update ...Ive decided to change the block and give it a xt look
temps look a bit better too
  #27 (permalink)
Old March 8, 2010, 07:03 PM
SugarJ's Avatar
Very nice. Nice macro shots too!
  #28 (permalink)
Old March 9, 2010, 04:46 AM
gingerbee's Avatar
nice shots but with out ambient temps this means very little. what if your in your garage @ 7c ambient temps tell how good a cpu block/rad are. ( just asking what your ambient is )
  #29 (permalink)
Old March 9, 2010, 05:17 AM
temperature #1 in the picture is the ambient temp... 22.3 c
  #30 (permalink)
Old March 9, 2010, 05:31 AM
gingerbee's Avatar
cool I personal prefer to use digital gauges to be sure that's just me.
home made gpu water block Lazypixel Water Cooling 24 July 11, 2009 07:50 PM
Best Water Block for i7 Bubbzilla Water Cooling 7 July 7, 2009 11:54 PM
[WTB] CPU Water Block Lpfan4ever Buy/Sell & Trade 10 March 4, 2009 06:00 AM
[FS] 4870x2 with water block brewer265@ Buy/Sell & Trade 20 January 12, 2009 04:51 AM
EK Water Block miggs78 Water Cooling 20 October 12, 2008 06:13 PM
