-   -   lga 1156 (http://www.hardwarecanucks.com/forum/water-cooling/27778-lga-1156-a.html)
phil3_66666 January 14, 2010 04:51 PM
lga 1156
Hi everyone, im looking for a new block for my i7 860, i know lot of thing about lga1366block but lot less on 1156
i already own an ek supreme lt in pass and realy love it, but it was great with flow in E/W orientation on lga1366, still good with lga1156?
right now was i can buy in canada is, gtz, xt, supreme, supreme lt, hk 3.0
2 block fithing my budget is supremelt(nickel version) of apogee xt
for what i know xt get bether temp than lt, but i read lot of thing about quality probleme..
what did you think about that?
maybe someone have a roudup with lga1156?
Thanks
Phil
miggs78 January 14, 2010 06:05 PM
Thanks
Phil
All you need is EK - Mounting plate Supreme 775, 1156 & 1366 Mounting plate Supreme 775&1366 [Mounting plate Supreme 775&1366] - $7.84 : DazMode, Watercooling enthusiasts store
Serious that Supreme LT Block is really good, stay with it.. the XT might have a good performance, but the quality isn't good, I wouldn't want to lay hands on a block that the internals are messed from new, that product will not last long.. Unlike a supreme, c'mon EK makes real good quality stuff.. stay with the block, or ima come with daz (dazmode) and beat ya :haha:
phil3_66666 January 14, 2010 06:21 PM
thanks for your reply, but like i say, i own it in the pass, sold long time ago...
my option are geting another one or xt..
edit: the plate you linked is to fit old supreme(non lt) on 1156 or 1366
Dazmode January 14, 2010 06:27 PM
I would take HK or new generation Supreme HF (NCIX has it and we will have too in a week). If you're on budget LT is hell of the block, I use it myself.
phil3_66666 January 14, 2010 07:44 PM
I think i will go with the lt, since HK are out of my budget and i dont realy like the supreme(dont know why)
Fudd Rucker January 15, 2010 11:02 AM
im using an EK supreme and it works great, i am going to invest very soon in a backplate though to make things fit better then just bolt through.
aCid888* January 17, 2010 02:40 PM
YGPM.
