Old January 12, 2010, 09:36 AM
Fudd Rucker's Avatar
Default Half height 140mm fans?
As the title states, do they make half height 140mm case fans? Trying to work with my stupid lancool K6-2 and figuring out where to cram a MRC220 radiator.I was thinking a half height 140mm fan would fit on the radiator if I top mounted it but im not sure where or if they make them half height. My google-fu is weak today as I was up all night working.
Swiftech MCP-655 | EK Supreme Acryllic
XSPC 360 | DD Dual 5.25"
Primochill 1/2" Tubing | 3 x 38mm Kaze 3000rpm
EK Nickel GTX 480
Old January 12, 2010, 11:57 AM
lowfat's Avatar
Can you explain what you mean by a half height fan?
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old January 12, 2010, 12:03 PM
MarkOne's Avatar
120/2 = 60 , I guess he mean the thickness
Old January 12, 2010, 12:04 PM
PLg PLg is offline
I believe he meant slim, not 2.5cm
there was a topic about it, let me find it, but they were 120. not 140
edit : Thin Fans
Old January 12, 2010, 12:07 PM
Yes thats exactly what I meant, I vaguely remember seeing that thread but didnt remember where. 120mm half height would work as well too.
EK Nickel GTX 480
Old January 12, 2010, 12:09 PM
MarkOne's Avatar
honestly I will change the case if you want a rad solution inside, I have a K 62, I don't see my self putting a rad inside.
Old January 12, 2010, 12:12 PM
PLg PLg is offline
Yeah and be careful with the low cfm
Old January 12, 2010, 12:32 PM
What I plan on doing, and its worked before was to mount the rad where the stock 140mm fans are and place a set of half height fans pulling air off it and to put the 140mm fans inside the case pushing air out of the case so between the 2 low CFM sets of fans (2 x 140 pushing air over the entire rad + 2 x 120mm slim fans pulling air off it. Ive measured everything and it would appear to fit.
EK Nickel GTX 480
Old January 12, 2010, 01:25 PM
lowfat's Avatar
120mmx15mm fans if they exist will not have enough static pressure to be any use on a radiator.
Old January 12, 2010, 04:24 PM
gingerbee's Avatar
me and you both maybe on the back but it's not the case for water cooling . jmo
What's a good 140mm fan? no_pulse Air Cooling 6 November 25, 2009 07:01 PM
Noctua Introduces NF-P14 140mm Premium Fan [PR] FiXT Press Releases & Tech News 21 October 30, 2009 10:30 AM
Undervolting Scythe Kama Maru fans (140mm fan recommendation thread) steers Air Cooling 1 July 19, 2009 10:11 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 03:32 PM
half hight vid card with half hight back plate tzetsin Video Cards 11 June 17, 2009 09:00 PM
