Old October 2, 2007, 03:21 PM
Cptn Vortex's Avatar
Default Help with WC setup
Hey all, I have a Swiftech H20-220 Apex Ultra+ on the way, and I am wondering the best way to set it up, including loop order and flow.
The RAD is going into a TJ09, at the top, moded a bit.
Cooling a P35 Chipset, 8800GTX ACS3 edition, and a Xeon X3210 Quadcore, which is going to get quite hot. How should I have my loop set up?
Thanks guys!
Old October 2, 2007, 03:30 PM
3.0charlie's Avatar
res - pump - rad - cpu - NB - VC - res.
Make sure that the res is located higher than the pump.
Old October 2, 2007, 04:26 PM
Patriote's Avatar
ALl that load on a pour MCR-220 ? I doubt you get any good temps with that. I'd watercool the CPU and NB only if you plan on overclocking your CPU.
I agree with the loop Charlie posted above.
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old October 2, 2007, 04:46 PM
Yah, that's kind of what I had in mind. Do you think the single 2x120mm RAD will be enough? I was maybe contemplating adding a second 120mm rad to the back
Old October 2, 2007, 05:36 PM
3.0charlie's Avatar
If you do, one possibility is res - pump - rad - cpu - rad - NB - VC - res.
Or
res - pump - rad - cpu - NB - rad - VC - res.
Old October 3, 2007, 11:37 AM
Hmm, tempting to throw a second RAD in there....I have a front Kama Bay in my TJ09, I should be able to put a 120mm RAD in there..... Wicked. I'll be sure to get some pics up soon, when I get the kit.
Old October 3, 2007, 12:18 PM
3.0charlie's Avatar
Do so. I don't think one dual-rad can handle all that heat load.
Stack 830 SLI setup Robilar(OCN) Case Mods, Worklog & Gallery 9 March 16, 2008 01:19 PM
WC setup Dark Water Cooling 24 January 14, 2008 06:02 PM
how does this setup look? moditir Water Cooling 24 August 26, 2007 09:41 AM
FTP setup problem Phredd Smytthe Networking 35 August 18, 2007 09:56 AM
New Watercooled Setup cdn_Madrach Water Cooling 41 March 11, 2007 11:48 AM
