<~----> Watercooling Mock-up for build - Hardware Canucks
Old January 9, 2010, 02:07 AM
Default Watercooling Mock-up for build
Hey guys, I am having a little trouble sorting out exactly how i want to set my rig up. I have made a crappy mock in Paint and a list of fittings I think I will buy. all are compression and 1\2 tubing. First an image of the interior. I already have the rads in place and my second pump is on its way. I already have all the blocks as well.
And this is the image of the mock-up. even color coded. red is the CPU loop and black is the GPU loop. The fitting list is as follows.
Pumps:
2 Right angle
2 Straight
Rad 1:
2 Straight
Rad 2:
2 Straight
CPU:
2 Rotary
Res 2:
1 rotary
1 straight
Res 1:
1 straight
1 right angle
GPU:
4 extenders
4 right angle
So. my question and or query. Do you think the fittings will work well like this? can I improve this without loosing the dual loop? and will the extenders attached to the right angle fittings work for the SLI solution?
I am planning on using 2 280's with D-Tek Fuzion GFX2's and the CI7 on a Apogee GTZ.
Death to Apple
Old January 9, 2010, 05:30 PM
rai_polo's Avatar
Res 1 can't empty into the gpu blocks, it has to go to the pump first. Only problem I see.
Heatware
Old January 9, 2010, 05:39 PM
ZZLEE's Avatar
Default T fore draining
put maybe some T in so it is esier to drain system. some T are made with tempature sensor to monitor temps.
Old January 9, 2010, 06:17 PM
AH! so it does. i will have to reverse the flow. as for the T-fitting, I forgot about them. will have to buy em.
Death to Apple
Old January 10, 2010, 07:48 AM
KaptCrunch's Avatar
loose the right angle fittings they kill flow go with 45's
IMHO use 2 "Y" fittings on the SLI set-up going parrelle
Old January 11, 2010, 10:11 AM
Ok, and "y" fittings? in what way exactly?
Death to Apple
Old January 11, 2010, 10:28 AM
SugarJ's Avatar
He's suggesting splitting the flow between the cards, rather than flowing through one card then the other.
Old January 11, 2010, 11:01 AM
Ah. I'm trying to figure out how that would work in my head. and i'm having problems considering the flow. how well would that work?
Death to Apple
Old January 11, 2010, 11:06 AM
MarkOne's Avatar
I will not do that, if for what ever reason, water start to flow more i one card than the other, you are dead .
Old January 11, 2010, 12:06 PM
Thats why I automatically did the card to card loop, not splitting it. But if there is a benefit to it, I will consider. altho. the cards are being cooled by a big rad so.
Death to Apple
Is this a Mock? hohohee Off Topic 37 January 8, 2010 08:40 AM
New watercooling build is complete. Dazmode Case Mods, Worklog & Gallery 19 December 29, 2009 01:11 AM
Watercooling Build: Looking for input! Sagath New Builds 28 April 5, 2009 11:23 PM
Loop mock up element291 Water Cooling 12 March 4, 2009 07:49 AM
Coolermaster Cosmos S Non-XSPC review on a Watercooling build Dashock Member Reviews 72 October 25, 2008 06:33 AM
