Old January 10, 2010, 08:06 AM
KaptCrunch's Avatar
Originally Posted by biff
Usually it's the residue left behind by evaporated coolant that causes issues not 'blow-ups' caused when the component was wet. Since you've pretty much go nothing to lose at this point I'd give the components in question a good wash down with a solvent like say isopropyl, and give a little scrub with a paint brush... then let that dry completely and retest. That saved the components that seemed to be pooched after I ended up with coolant all over the place after an explosion.
yes your correct had 2 120gig HDD get with soaked 50/50 PG antifreeze
rinse & dried them out after 2 days didn't work
they sat around, till spring cleaning, before tossing in garbage
tried 1 more time an they came to life
Arctic Cooling Accelero TWIN TURBO Pro Cooling for GPUs FiXT Press Releases & Tech News 6 November 16, 2009 12:51 PM
OS advice... somecanadianguy O/S's, Drivers & General Software 18 October 9, 2009 08:20 AM
Passive cooling/silent cooling Cowboy Air Cooling 9 September 17, 2009 11:38 AM
First time water cooling, need advice. Blam Water Cooling 56 July 20, 2009 05:54 PM
need advice Rapid-X CPU's and Motherboards 7 January 30, 2008 03:15 PM
