-   -   Heatkiller + Backplate (http://www.hardwarecanucks.com/forum/water-cooling/27350-heatkiller-backplate.html)
JD January 3, 2010 02:37 PM
To those of you who have the Heatkiller block along with the HK backplate, how did you go about mounting it?
Seems to be varying thoughts on it, and well I don't want to do it the wrong way and then have to redo it all.
stoanee January 3, 2010 03:37 PM
http://www.watercool.de/_uploads/Fil...30_A5_ENG_.pdf
JD January 3, 2010 04:12 PM
Originally Posted by stoanee (Post 311558)
Only that it doesn't answer my main question of which way the backplate should face. I get the general feeling that the WATERCOOL logo should be readable once mounted, but some people didn't do it like that...
SugarJ January 3, 2010 05:32 PM
My backplate is mounted with the logo facing the outside of the case, i.e. readable. Don't forget to use the red spacers.
JD January 3, 2010 08:04 PM
And how far did you screw down the block? 19.6mm-20mm?
SugarJ January 3, 2010 08:12 PM
As close as I could get to that. I didn't have a metric tape handy.
