Old January 3, 2010, 11:21 AM
Default i5 water temps
i feel my temps are abit high im geting 30 to 35 doing nothing and when useing occt 65 to 70 im useing a gtz cpu block and pa 120.3 rad i5 at 4gz 1.33 vcore
i would like to know if these temps are ok and if not what it should be at
Old January 3, 2010, 11:24 AM
Arinoth's Avatar
Where is the radiator located?
Old January 3, 2010, 11:37 AM
out side of the case on the back , sliver stone raven
Old January 3, 2010, 12:12 PM
MarkOne's Avatar
I get less than 65'C with a 212+ with 4 Ghz and 1,32 volts , what is your room temp ?
Old January 3, 2010, 12:36 PM
20 to 22 could it be the fans im useing i have them in push pull , 45cfm
Old January 3, 2010, 01:35 PM
sigel's Avatar
Default High Temps
Always double check if your block is seated properly, when temps don't seem right. A caliper helps to determine if each nut is tightened evenly. Those temps seem kinda ok to me although i would expect slightly lower load temps from a 120.3 rad.
Old January 3, 2010, 01:45 PM
well thats just on linepacking the other cpu test on occt never gets much over 60 , 53 to 60 but still it seems like alot of ppl with air are doing around the same or better, i have checked the block a few times now. i also used thermaltake coolant 1000 , maybe i should have used water ?
Old January 3, 2010, 01:53 PM
MarkOne's Avatar
are you sure you don't invert the outlet and inlet, on the gtz
Old January 3, 2010, 01:54 PM
gingerbee's Avatar
ambient temps and barometric pressure matters.
Old January 3, 2010, 02:00 PM
lol i had to think about that for a sec , i have it set right , you dont think the fans i have might be to weak ? yate loon 1200rpm 45cfm 24 db that and the thermaltake coolant is really all i can think of.
what are some average i7 920 temps under water? quikgp Water Cooling 32 June 18, 2009 03:06 PM
water cooled q9650 temps bc_tileguy Water Cooling 3 May 24, 2009 12:34 AM
Water Temps seem...high. Sagath Troubleshooting 4 April 6, 2009 07:27 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 01:34 PM
temps Kassela Troubleshooting 7 March 13, 2008 03:46 PM
