Old December 28, 2009, 03:40 PM
Default Completing my WC setup
Hey all, going to be going to WC in January. My goal is a verrrry quiet computer with no modding. Rad(s)
inside the case if possible. I will be cooling the following.
q9300 (already had a d-tek fuzion v1 given to me)
dfi lanparty p45-t2rs (was also given a swiftech chipset block)
2 XFX 4890s (have 2 full coverage blocks for these as well)
guess the rest of the specs don't really matter.
It's in a cm690 (the nvidia one). Not too worried If i have to spend a bit extra to get it all inside the case. But my thought was that I would do a dual rad up top and maybe a single at the back if necessary. For the fans I'll get something with strong airflow and use a fan controller for when I'm not gaming. Again I dont want to have to rip the case apart (eg, modding the top to fit a triple rad) Now I just need to figure out the rest of the parts I need and how I'm going to put em in.
Suggest away!
Old December 28, 2009, 06:14 PM
Yea, budget isn't too much of an issue, those parts seem easily doable. Is the price difference worth getting those parts over their swiftech equivalents?
Old December 28, 2009, 06:25 PM
bottle's Avatar
If budget is an issue, you might as well get the Swiftech Rads instead.
However these rads are very well known for great performance with low RPM fans.
Here's a comparison of several models in the triple variation.
skinnee labs - Triple Radiator Performance
Old December 28, 2009, 07:54 PM
Dazmode's Avatar
If you get large case like Cosmos S or HAF932, you can fit triple rad inside without any problems. If you are after silence, the game is easy: bigger rad(s) + slow fans balance.
I suggest against GELID on radiators specifically, try YL or Schythe or, if you can afford, 38mm/55mm fans that under volts well (you will need fan controller for that).
Better CPU block will help too, but it is optional.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old December 28, 2009, 08:20 PM
AmuseMe's Avatar
I would recomend the Gentle Typhoon fans for sure for radiaotors. Grab the 1850RPM, and a fan controller (if you want) and your set. NCIX.com - Buy Scythe Gentle Typhoon 120MM Case Fan 1850RPM 28DB 58.3CFM - D1225C12B5AP-15 In Canada.
Old December 29, 2009, 05:06 PM
Yea, well im getting the cpu block for free so I dont want to go through the hassle of buying a new one and selling it... A new case Isn't a bad idea though.
Old January 4, 2010, 05:29 PM
Ok, based on second-hand deals and assuming I keep my case this is the setup I have come up with. It consists of a 120x2 swiftech rad w/ res. a 120.1 swiftech rad, laing d5 pump. the fuzion v1 cpu block and ek full coverage blocks on the 2 video cards.
Also included is my colorful failed mockup
Old January 4, 2010, 05:33 PM
Dazmode's Avatar
Is there a T-line or res?
How will you fill the loop?
Old January 4, 2010, 05:46 PM
the 120.2 swiftech has a built in res.
Setup, again? martin_metal_88 HardwareCanucks F@H Team 4 November 9, 2009 02:36 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 06:17 PM
WC setup Dark Water Cooling 24 January 14, 2008 06:02 PM
Help with WC setup Cptn Vortex Water Cooling 6 October 3, 2007 01:18 PM
how does this setup look? moditir Water Cooling 24 August 26, 2007 10:41 AM
