  #21 (permalink)
Old March 24, 2010, 08:51 PM
Supergrover's Avatar
Bet it is one of the 655 that had the wiring assbackwards, when it is hooked to a molex is it red to red if so thats the problem. Switch the wires to the other side of the molex plug.
R.I.P.
  #22 (permalink)
Old March 24, 2010, 08:56 PM
you sir, are correct.
  #23 (permalink)
Old March 24, 2010, 08:58 PM
Thought so, glad to help.
R.I.P.
  #24 (permalink)
Old March 24, 2010, 09:50 PM
ahhh 1 hr into leak testing and it looks like the.... radiator is leaking? its not at a connection point, its on the side of it, slowly dripping
  #25 (permalink)
Old March 24, 2010, 11:37 PM
Upon further testing I've confirmed its definitely the rad and not any of the connections. Craaaaaaaap. Time to hit up the BST again, hopefully I'll get something that works this time....
  #26 (permalink)
Old March 25, 2010, 02:29 AM
Jackquelegs's Avatar
Canadian tire/ Home depot.
Buy some epoxy
http://www.canadiantire.ca/AST/browse/6/Tools/SpecialtyTools/TapeGlueSealants/PRDOVR~0383792P/JB%252BWaterweld.jsp
This stuff is pretty good for leaking radiators. I have a PA120.2 with multiple punctures fixed with it
Iapetos
Zephyranthes
  #27 (permalink)
Old March 25, 2010, 06:15 AM
AmuseMe's Avatar
Solder works too, and it disapates heat better than epoxy However, if it is just a tiny hole, I don't think it will make a difference at all if you use epoxy. If it did, I'd get a new rad.
  #28 (permalink)
Old March 25, 2010, 08:56 PM
amuseme it's actually the rad you sold me a couple months ago ...
I took it out of the loop and checked to see exactly where the leak is. theres no way I'm going to be able to fix it. Guess its time for a feser 240.... ill post some pics and temps when thats in and running.
  #29 (permalink)
Old March 25, 2010, 09:07 PM
AmuseMe's Avatar
Is this the first time you used it since you bought it? The day before I took my loop apart to sell it, it was fine. Anyways, lets take this to PM's. Send me a PM, I may work out a refund with you
Setup, again? martin_metal_88 HardwareCanucks F@H Team 4 November 9, 2009 02:36 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
WC setup Dark Water Cooling 24 January 14, 2008 06:02 PM
Help with WC setup Cptn Vortex Water Cooling 6 October 3, 2007 12:18 PM
how does this setup look? moditir Water Cooling 24 August 26, 2007 09:41 AM
