quick question about my setup
While doing a quick dusting of my computer today I noticed that my coolant levels looked low (like 5mm) from the top of my EK multi-option re. So I decided to top it off, but when I unscrewed the top off of the res the coolant levels returned to near normal levels as if the system was pressurized and was preventing the coolant from returning to the res. The computer was off when i tried this aswell.
I have read about different ways coolant level can drop, such as a leaking fitting, evaporation, and a very slight amount seeps through the tubing over time.
My loop consists of an HK 3.0 CPU block, EK EVGA x58 motherboard and mosfet watercooling kit, TFC 360 rad, mcp655 pump, EK multi-option res, primochill primoflex tubing, bitspower and TFC compression fittings.
My system runs for about 4-8 hours a day.
How much coolant should I lose over lets say a 3 month period, which is when I topped my res off last, due to normal evaporation and what not?
And, is it normal for the system to have some (very little) pressure in it when it is first shut down?
I also noticed that when I first turn my system on the coolant levels in the res drop a bit, maybe close to 1cm. Might there still be a bit of air in my rad?
edit-updated sig.
Main- i7 920 C0 @ 4.0, EVGA X58 SLI FTW Mobo, 6GB Corsair XMS3@2000mhz, EVGA GTX470 in SLI, Corsair AX1200, Corsair Obsidian 800D, 2 OCZ 60GB Vertex in Raid 0, 4 WD 1TB Blacks, Logitech G19 keyboard, Logitech G9 mouse, Samsung SyncMaster 245BW.
WC Loop- TFC 360 Rad, HK 3.0 CPU block, EK -EVGA X58 full coverage motherboard and mosfet blocks, MCP655 pump with EK top, Scythe S-flex push/pull.
