Old December 25, 2009, 05:52 PM
bottle's Avatar
Default Copper + Ketchup overnight = ?
Hey guys.
I took apart my loop today and to my horror, I found a bunch of gunk/ stains on the insides of my blocks.
Not 100% sure what it is, but it doesn't want to come off easily. After a rinse, obviously it's still there.
I did a ketchup scrub, not much off, but definitely an improvement.
It's kinda greyish and in patches. Again, not sure where it came from.
I'm wondering if it's okay to let my copper parts sit in ketchup overnight, or is this timeframe too long, and will I possible corrode the blocks beyond repair?
All input is appreciated, thanks in advanced.
Old December 25, 2009, 07:56 PM
JD JD is offline
If all the gunk is removed, I wouldn't really worry too much otherwise. Don't think it affects performance that drastically.
As for the ketchup, not sure, and well I guess it depends on how many hours your "overnight" is.
Old December 25, 2009, 11:22 PM
bottle's Avatar
About 8 hours. I would think the weird layer of stuff would hinder performance.
Old December 25, 2009, 11:53 PM
sswilson's Avatar
Much depends on if it's just a discolouration, or if the "grey area" is something you can feel on the surface. If it's just discolouration it shouldn't affect temps.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old December 27, 2009, 01:15 PM
KaptCrunch's Avatar
not good to leave overnite best use for spot cleaning only {note its a mild acid} rense well after use
as SSWilson stated if can feel it that be corrosin best sand it out
Old January 3, 2010, 08:43 PM
biff's Avatar
Add some salt to speed up the action. Don't leave it over night.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old January 3, 2010, 09:49 PM
bissa's Avatar
this may be entirely useless in this case but what about using pickling vinegar? it is pretty harsh stuff and will eat through whatever you are trying to dissolve faster than ketchup (I'm pretty sure it would have a lower PH than vinegar, correct me if I am wrong). and it is a liquid so it will rinse out more easily.
[WTB] Copper NB or mosfet HS Varroa Buy/Sell & Trade 3 November 30, 2008 07:32 PM
TRUE Copper Heatsink! Killswitch Air Cooling 4 October 26, 2008 12:48 PM
TRUE copper version - coming soon CTA Press Releases & Tech News 6 October 1, 2008 11:16 PM
Scythe Ninja Copper +1! SugarJ Air Cooling 18 June 30, 2008 06:52 AM
New Ketchup flavored Windows Babrbarossa Off Topic 1 March 17, 2008 09:24 AM
