Old December 24, 2009, 04:22 PM
chrisk's Avatar
Folding Captain
Default Water-cooled folding rig
Hey guys;
Setting up the folding rig for water cooling. I ordered the EK Supreme and I got a backplate for it.
The backplate came with some spacers. I used them, and there was a little gap between the block's backplate, and the Asus' backplate on the back of the mobo (they call it the 'Stack Cool').
After mounting the block, there is no longer any gap and it looks like the water block's plate and the mobo plate are touching. There are no solder joints or anything touching though.
Is this OK? Will it cause a short?
Fold for team #54196
Old December 24, 2009, 04:34 PM
gingerbee's Avatar
it's just a back plate your fine
Old December 24, 2009, 04:38 PM
Both backplates are electrically isolated from the motherboard, so there will be no issues.
Old December 24, 2009, 08:05 PM
chrisk's Avatar
Folding Captain
Already started a thread about my project so I figured I would post an update here.
Using a TFC Xchanger 360 rad, EK Supreme block, EK Multires 150, and the Swiftech 655 pump. Just cooling the cpu (i7 920).
Currently leak testing, powered by my external DVD enclusure (the 12v molex connector in the enclosure).
Here is what the watercooling loop looks like now:
Lots of paper towels lol. I am kinda worried, this being my first loop I have done myself.
If you see anything completely wrong let me know. No leaks so far...
Old December 24, 2009, 08:29 PM
gingerbee's Avatar
nope looks good to me. but i like to run the pump to the rad then to the cpu block or which every block your using first if more then one.jmo
Old December 24, 2009, 08:50 PM
chrisk's Avatar
Folding Captain
Pump to rad? I am planning on adding a video card in the spring. I thought the pump would have to go after the res, and the res should go after the rad.
As long as it works now. Still no leaks, about 1.5 hours so far. I'll let it run all night, and hope that Santa does not mess with the loop tonight when he stops by.
Old December 24, 2009, 09:00 PM
Sagath's Avatar
Haha, did Angie give ya crap when she came home to her kitchen table covered in paper towels and PC parts? As to what Ginger was saying, and your reply: It matters little which order you put components in, as long as the res is feeding the pump. Any other order is just personal preference.
Btw, I really like that 655 setup mounted to the HDD rails 'sideways'. I'll remember that next time I redo my loop. I guess the only downside is its hard to use the speed control if you want to
Old December 24, 2009, 09:39 PM
Dazmode's Avatar
Looks good for me too.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old December 25, 2009, 12:20 AM
AmuseMe's Avatar
That is an opinion a lot of us like to say/ go by. Truth is though, as much as we like to say it, it doesn't mater on the placement of the loop. Go with whatever looks the cleanest as the water will eventually regulate it's temperature.
Old December 25, 2009, 01:01 AM
Looks nice.. HAF 932 FTW.. gonna be working on my loop too this weekend hopefully, similar loop, just a LGA775 build :p..
Nice build too, lots of white stuff, where can I get some, and the cost LOL :p.. Gotta say, leak testing done the right way, enough paper towels..
I actually admire you going for the EK supreme over anything else, even a heat killer.. very good block for the money..
water cooled q9650 temps bc_tileguy Water Cooling 3 May 24, 2009 12:34 AM
Water Cooled -NZXT Tempest jay51 Case Mods, Worklog & Gallery 48 October 3, 2008 12:26 PM
Antec 900 Water cooled....but need help oksir Water Cooling 9 August 25, 2008 11:25 PM
Water Cooled Tech Station chibi_man Case Mods, Worklog & Gallery 88 July 31, 2008 05:34 PM
Water Cooled Case Gallery! cyberspyder Water Cooling 5 September 19, 2007 01:11 PM
